[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    disable signature check, but it should be disabled by default... weird and my pack is signed...
    If the signature is disabled, after 'WTP Enabled' message the TWR reboots without apply the update.
    Have you got any other idea to test?
      Re-download? maybe a bad download.
      Try this one - > update_boot_MXQ.zip
      Some Ppl are having problems downloading from mediafire... it corrupts the downloads...
        Wooooow!!!! That's it!!!
        I'm really stupid. I haven´t checked the zip after download
        And the ethernet port works fine from the Amlogic configuration menu.
        Do you think this update will work with other firmware versions made for MK808B Plus?
          maybe... you need to use the dhd.ko from my rom and test it...
            With the MXQ, sometimes, when I change the video input to another source; ejm: television, and then return to the MXQ the video doesn´t appear. I must to power off and then power on to see Android again. Wïth the MK808B Plus and with the MXQ with other roms never happened before.
              With my mk808 i dont have problems if i change the tv source signal on my rom, so dunno :/
              Like i sayd this is stock 111k4 with some tweaks nothing more.. and of course a most recent kernel... maybe a new bug on the kernel with some type of tv's...dunno...
                The last commented problem, maybe be related with the stand-by problem?
                Is there any way to update the recovery for the MXQ to avoid leaving it in the MicroSD?
                Any posibility of fix the power off problem?
                Thank you again
                  Maybe, need to check it.. but the power off and stand by problems are only on mk808 dunno on the mxq...
                  Are you using CEC?
                  My next build it will go with the default recovery, then after 1º boot the user run a script(on terminal emulator) to flash the correct one or leave it as default, is beter like this.. users choice...
                  If someones fixes it on the source, yes...
                  Im now a bit off this, im finishing my retro-ps2(rpi2) and that is my project now... i have done this one only for fun... but i will update the build in the next days
                    Are you using CEC?
                    In the MXQ the power off problem is present, too.
                    No, I´m not using CEC. I have not. Anyone try it in this rom?
                    Anyway, the roms runs very well.
                    I'm waiting your next release.
                      Is there anyway of fixing / adding support for air mouse / keyboard,
                      I only have Left and Right mouse buttons working on my Tsm01,
                      was fine with original firmware.
                      Clone RT8723
                      Like how kodi 15 works well now.
                      Cheers
                        Clone RT8723
                        Cheers
                        i will check it
                          i will check it
                          Quick note, if it helps, original firmware has
                          Build number: KOT49H.20150618
                          Kernel Version 3.10.33 Thu Jun 18 15.37.07 CST 2015
                          If needed I can upload a copy in TWRP or system zip.
                            Hmm that is a new build, what is the build number? (Ex:128k3 or111k4)
                              This is what I have, maybe this is clone of a clone.
                                Ok ... seems I have another clone, ... anyway...
                                Superceleron, I prefer your rom, to use on these boxes,
                                is there anyway I can add support for the Air mouse Keyboard.
