[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
    Originally posted by mega-samu View Post
    There is some command or way to know the wifi without opening the mk? To insure ourselves that it is this wifi.
    Ok i have checked the kernel and same driver same config... i don't see no difference, i really dunno why works ok on some and on other don't and if i don't have the TVstick here is hard and very time consuming to debug the problem.
    Nop you need to open the stick.. is easy...
      v1.3 kernel f....... amazing !!!!
      ​thx superceleron
        It is the AP6212
          Thks mike77
          mega-samu i'm puzzled.. really... wtf..
          Later today i'm going to make a kernel from a different branch and post it herefor you to test it out.
            Hi superceleron,
            I have just installed your rom on realtek wifi version, however, the most important thing for me is adb and it does not work because some UI problem. When I plug the mk808b+ to my laptop, I can see it in adb devices and my TV screen flashes twice but no authorisation dialog. Without the possibility to press on dialog "OK" authorise my laptop for adb, I can't have adb :/.
            Now I keep getting "device unauthorized. Please check the confirmation dialog on your device." Any possible fix?
              Originally posted by kokonuts View Post
              Hi superceleron,
              Activate developer mode and see if it helps... i cant remember if is something there for that, if not you most edit build.prop on /system and change this "ro.adb.secure=1" to 0 and reboot...
              Mega-samu plz test this boot(kernel) : https://mega.nz/#!VoA1iZjR!1JfMg0slv...1Gg-_kFB2pZn6c
              regards
                regards
                Thanks, I have activated the developer options if that is what you mean. I don't think the "ro.adb.secure=1" will survive the reboot, because it is "ro" readonly. I think you could make that change when you release the next version of the rom, or fix why the RSA finger print dialog is not shown.
                  dind't test it but try it.
                  did it show the dialog on the stock rom? i cant test it now my test monitor have gone berserk... and the tv is always occupied...(kids, wife..)
                  Yes noted for the next rls
                    I've tested the 1.3 version of the rom in the MXQ S85 and runs pretty well too.
                    Ethernet and TWR work like a champ without the need of doing anything. I can`t test the HDMI CEC cause in my TV doesn´t work well. Anyone has tested it?
                    Like the other version, reboots instead of shuts down. Really the most annoying issue. Youtube´s app doesn´t work. The rest works very well. FHD in Kodi, navigation in Chrome with little lag.
                    I suggest you removing apps like Apptoide and other non-essential apps that can be installed easily if needed, including GAPPSs that I would add as an option.
                    The TV sticks that works in OpenELEC rom in this doesn´t work. Therefore I've returned to OpenELEC but I´ll try all your roms if I can.
                    Thank you very much again for your work.
                      Thks for the heads up, about CEC i don't have the MXQ but should work ok, on the MK i know it work but on my TV not with the hdmi cable that come with the device, but other works like a charm.
                      The shutdown is a bug on the kernel, and i still didn't find out where...
                      youtube... damm lol i didn't test that one i just put it there LOL.. i will check
                      About GAPPS i know what you mean and i already think about that, i only didn't do it because of the noobs so i leave it like that the more experience users can just take out what they don't need
                      Of course most of the TV sticks they don't work as i have most of them off :P i need to make the kernel smaller so...
                      Thks
                        regards
                        Already the wifi works with this patch. Thank you superceleron.
                          Nice that is not the final... i need you to make another test if you can
                            Okay, spend it to me and attempt that "my tester" it prove.
                              here you go.
                                Hi superceleron
                                I have a mxq s85 fw 111k4
                                With your rom 1.3 i have ethernet but i haven't wifi.
                                With your experimental boot3, i have wifi, but i lost ethernet; with boot 4 the same as boot 3, but with some screen flash.
                                Best regards and good job
