[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
First of all, thank you very much for your efforts to make this rom. I've tried in a MK808B Plus and runs pretty well.
I own another TV Box model with the same soc; MXQ S85. The roms are mostly compatibles with the MK808B Plus's roms, and yours too is compatible with it. The only missing feature, like the rest of the MK808B+ roms, is the ethernet port. You say that uses the Openelec kernel and the MXQ S85 has the same Openelec rom that the MK, so, I dont know if it is very dificul, but could you make another verssion of your rom for the MXQ S85 with buit-in ethernet conection support?
I'd prove what you need on the MXQ
Originally posted by Txemoto View PostFirst of all, thank you very much for your efforts to make this rom. I've tried in a MK808B Plus and runs pretty well.
Thank you for the rom, as I was looking for one with the updated kernel.
Not a fan of the custom graphics (although that is taste, and most can be changed) and haven't tested the 360 controller to see if the D-Pad is working which is a common problem but can be fixed by doing the method in the following post:
Overall however, thanks for working on this.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by ididmytime View PostThank you for the rom, as I was looking for one with the updated kernel.
Yes is a tasteall can be changed
Dpad works but theres a problem if you press long time to the left it brings the power menu... but yes you can use that fix and it will work just fine
Sure, share it and I'll test it very quickly. In fact, I have your rom in the MX so, I`m waiting for...
1º test to enable it on the "normal" ethernet menu, if that dont work go to advanced settings and activate it there.
Did it work.....?
i guess it worked...
Sorry for the delay to respond.
I´ve tried to go to the recovery from the Reboot program and with the toothpick and in both the recovery screen blinks (see attached photo) and I don`t see the option to install the update. I´ve tried from the update program in Android. I can´t see if installs the update. I only see some words in red color.
I´ve used too the OpenELEC recovery and the result is in the second photo.
I´ll try what you want again.
Thanks again for your efforts.
You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
http://freaktab.com/forum/tv-player-...and-acemax-mxq
He remembers that the recovery stock, not flash files without signing.
P.D: Another user with AP6212 has brought, his that him does not work the wifi.Last edited by mega-samu; 17 August 2015, 18:00.
There are currently 1870 users online. 2 members and 1868 guests.
