[ROM] Superceleron 1.4B, MK808B Plus AP6210/6212 and Clone RT8723 and MXQ S85.
The mk808b is rockchip 3066 and the mk808b plus is the amlogic S805
You cant use the rom from mk808b on the plus and vice versa..sorry had to snap a pic of this
Originally posted by superceleron View PostDamm that is a small pic LOL cant see nothing...
But use a usb stick formated as fat32.
Ok 1º go where http://freaktab.com/forum/tv-player-...mlogic-devices and download the twrp image.
2º boot to android and change you resolution do 720p(very important) after flash you can change to 1080p or auto again.
3º put the twrp you downloaded on the root of the sdcard(format fat32) don't forget to rename the file from "TWRP_2.8.7.0_MK808b+.img" to "recovery.img"
4º put the gapps zip on the same sdcard
5º put the sdcard on the device
6º boot to recovery by reset button and flash.
RegardsLast edited by superceleron; 23 September 2015, 17:07.
Hi superceleron, you would have some link to the stock rom model EC-mk808b? With your version, USB (common and OTG) interfere with wifi (as You've mentioned). The Google TV Remote app never found the device. So that it becomes very difficult to handle me ... Thanks!
Originally posted by luisni View PostHi superceleron, you would have some link to the stock rom model EC-mk808b? With your version, USB (common and OTG) interfere with wifi (as You've mentioned). The Google TV Remote app never found the device. So that it becomes very difficult to handle me ... Thanks!
but here is the stock rom: https://mega.nz/#!VxBFgJ5L!sd-bETMW6...vOOYFycpE2JHaA
Regards
The google tv-remote to work you need to install gapps and enable it on the settings.
Regards
Thank you very much again.
Hi Celeron.
Thanks for your job. The rom works smoothly and without errors but I have a question about Kodi. How do you managed to show the cpu temperature in kodi. I tried to put this line: <cputempcommand>sed -e 's/\([0-9]*\)[0-9]\{3\}.*/\1 C/' /sys/class/thermal/thermal_zone0/temp</cputempcommand>
but it doesn´t works.
Thanks superceleron was impossible for me to enter recovery. I suspect that when you install your rom on which originally brought the stick something was not installed correctly. The only way to install the rom stock you gave me was through Amlogic USB Burning Tool. Then I return to install the rom superceleron.
If with this still don't work, your kernel have that disabled or is missing the driver.Last edited by superceleron; 24 September 2015, 23:03.
Originally posted by superceleron View PostOk 1º go where http://freaktab.com/forum/tv-player-...mlogic-devices and download the twrp image.
Regards
Those recovery didn't work for me (TWRP 2.8.7.0 MK808b+) any way, I installed another version (TWRP 2.8.1.0) and same issue, gapps flash right aparently but after boot android it didn't are there.
Maybe Mini gapps dont work on clone RT8723
Regards
There are currently 1919 users online. 1 members and 1918 guests.
