Lollipop - Wasser Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
    version 3.1.4
    • add "lock screen" support, which is needed for multiuser mode
    • add daydream support
    • add support "Adjust display refresh rate" , enable by default in Setting->Display
    • fix color issue in es file manager
    • improve wifi performance
    • clean up UI
    • improve UI and video streaming
    • add A2 Lite airmouse support
    • add latest security fixes
    • update google apps
    • fix a lot of other issues
    Firmware download: wasser-firmware-lollipop-3.1.4-i68-1000lan-rk3368
    version 3.1.3
    • add mullti windows support
    • add WiFi 5Ghz support
    • security fixes
    Firmware download: wasser-firmware-lollipop-3.1.3-i68-1000lan-rk3368
    version 3.1.2
    • built from lollipop 5.1.1 SDK
    • firmware based on release-keys instead of test-keys to improve app compatibility
    • rooted
    • unified storage (emulated SD)
    • youtube 1080p/1080p60fps support
    • netflix support
    • init.d support
    • multiuser support
    • nfs filesystem support
    • exfat filesystem support
    • ir remote full support
    • add hardware keyboard menu
    • add longpress menu key to show/hide navbar
    • add power off button in navbar
    • add sleep, reboot into recovery, reboot into bootloader in menu
    • add support "dont wake up devive with mouse movement in suspend mode"
    • add new mouse pointer
    • fix usb sound issue, microphone issue
    • fix wake up issue in sleep mode by the stock IR remote
    • fix random ethernet MAC adress
    • fix some isssue in launcher3 and improve system performance
    • fix read/write permission for storage
    • improve IO performance
    • update busybox
    Firmware download: wasser-firmware-lollipop-3.1.2-i68-1000lan-rk3368
    Updating instructions, updating tools and drivers download: flashtool
    Please report feedbacks so i can improve it in future release. Thanks
    Be aware: it is your own risk!
    Can not be downloaded
    The requested URL /wasser/wasser-3.1.2-beelink-i68-1000-rk3368_box.7z was not found on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.??
      download url is fixed. Please try again
        wasser pleace create firmware for Beelink i68 100MBit Ethernet too. I will test yours firmware as soon as you release it !
          All works fine on Tronsmart R68, except Kodi.
          Thanks.
          UPD The firmware exhibited excessive sharpness of the image, which leads to the appearance of artifacts. How to return the picture settings as in stock firmware?
            Hi all,
            I have built new wasser kodi 15.2rc2 which should fix the passthrough and 4k video streaming. It's a big improvement in this version. Please take a look at the first post to get the Download URL, Please test it and report the feedbacks
            Thanks,
            Wasser
              Originally posted by wasser View Post
              Hi all,
              Thanks,
              Wasser
              Maybe you need to specify that is based on zidoo open source.And follow GPL
                Please Wasser, firmware I68 100M please!!!
                Regards
                  On beelink i68 do not work wifi. When I turn it on, nothing happens. Hotspot also unavailable.
                    And passthrough from spdif have problems. Now sound have cuts i.e. sound goes without stopping(non-stop) and periodic trimmed for one second. Also sound goes like lower for a tone. Like converted to 48000 Hz from 44100 Hz.
                      Agree. The sound not stutters, but missing a second of sound.
                        My wi-fi is not working either - no networks are showing up in the wi-fi list, even though wi-fi is turned on. Everything else so far looks good!
                          version 3.1.2
                          • rooted
                          • netflix support
                          • init.d support
                          • multiuser support
                          • update busybox
                          Wasser Kodi-15.2rc2 (auto refresh rate switching, rockchip codec, passthrough) download: wasser-kodi-15.2rc2-lollipop
                          Please make a 100m lan version
                            Hey You are in the wrong Thread go to the 100 MBit Thread to get that build
                            Michael T.
                            3.0.x Lollipop firmware RK3288 By Wasser/ My Standard Remote IR
                            CVSB-K200-Wireless Mini QWERTY Keyboard / Motion Mouse for Android RF
                            Rii Mini i25 Qwerty Keyboard/Motion Mouse For Android RF
                            Media Flow Suite ... 24 TB ReadyNas Pro wired 1 GB Ethernet
                              works good on tronsmart r68 meta - gigabit,
                              except for HDMI CEC.
                              Great work Wasser looking forward to your next release.
                              not sure if its possible but can the IR receiver be programmed to recieve inputs from any remote?
