Gesendet von meinem JY-S3 mit Tapatalk
Lollipop - Wasser Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Originally posted by Dodok View PostLike me, you have AP6330 chip for Wifi/Bluetooth. We have to wait Waser's next relase of the firmware. He said that "mayby" will made it for AP6330 devices... We cross the fingers
Stutter With Youtube Client -- And to a lesser degree with other streaming apps
I have noticed an audio and video stutter with the Youtube client (10.47.51). I had this same problem with Wasser 3.12 and still have it with 3.13. I am running a 4K TV at 4096x2160p-60(YCbCr420), so the Beelink R68 has a lot of pixels to deal with.
The stutter lasts about 2 seconds and it happens within 5 seconds of starting the video - then again about every 20-30 seconds until the video is fully cached.
Member "DaPimp" mentioned something about Wasser tweaking the CPU govenor in the next firmware build 5 days ago (1/16/16). This might help. I also suspect it may have some to do with writing to memory and/or multitasking.
I did not have this trouble with the stock firmware, but Wasser's firmware has so many more useful features.
Originally posted by imperatores View PostCan i return to the previous version 205L?
You can download the original 201L firmware, flash the Box then upgrade to 205L. Or download the 206L firmware.
206L
Originally posted by tsukaza View Post
p.s: i use the wasser firmware 3.1.3
I have a VicTsing I68 2/8 with AP6330, I looked inside.
If I use rom from tronsmart 205L1 : http://www.tronsmart.com/?p=5133
Wifi and BT are OK.
If I use Wasser/Ionix rom, no wifi, no BT
In the dmesg from Tronsmart rom i can see :
<6>[ 2.614698] [0: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_init
<6>[ 2.614979] [0: swapper/0: 1] [WLAN_RFKILL]: Enter rfkill_wlan_probe
<6>[ 2.615054] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335
<6>[ 2.615071] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
<6>[ 2.615085] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
<6>[ 2.615101] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
<7>[ 2.615163] [0: swapper/0: 1] of_get_named_gpio_flags exited with status 100
<6>[ 2.615177] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 100, flags = 0.
<7>[ 2.615192] [0: swapper/0: 1] of_get_named_gpio_flags: can't parse gpios property
<7>[ 2.615214] [0: swapper/0: 1] of_get_named_gpio_flags exited with status 102
<6>[ 2.615227] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 102, flags = 0.
<6>[ 2.615242] [0: swapper/0: 1] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
<6>[ 2.615286] [0: swapper/0: 1] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V
<6>[ 2.615301] [0: swapper/0: 1] [WLAN_RFKILL]: Exit rfkill_wlan_probe
I have the same log with ionix zidoo v1 !
Same driver ?!
Originally posted by reksio34 View Post
Wifi and BT are OK.
Same driver ?!
Wasser's firmware did not include the AP6330 drivers during the build. We are waiting for him to include AP6330 on the next build.
Tronsmart's firmware must be build with AP6330 and AP6335 binaries.
In desmg we can see this :
<6>[ 2.261767] [0: swapper/0: 1] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335
In my case I have an AP6330, and the Zidoo v6 ROM, but the kernel find a AP6335.
Then I changed the name of the nvram_AP6330.txt in /etc/fimrware to nvram_AP6335.txt, reboot .... and ..... the wifi is OK !!! but no BT.
Unit Does Not See 2TB USB Hard Drive
The Beelink R68 (GigE) with Wasser 3.13 does not see my 2TB Seagate hard drive (5.25", USB 3.0, not USB powered). About 80% of the time, the unit cannot even see the hard drive with ES File Manager. Sometimes ES File Manager can see it, but it report its size as 996MB - not 2000MB. Kodi and SPMC can never see the hard drive. When the unit can see the hard drive, I can see and use all the files on the drive, but ES displays the file name in light grey. The drive works fine on my other Wasser box (Tronsmart Orion RK3288) and other PCs. Is there anything that can be done?
Great trick.
Apply this fix with the Ugoos UT4 2016 release 0.0.2.b firmware on my Beelink i68, both WiFi and Bluetooth are working, also stuttering
is almost gone on YouTube. Also Blue LED works.
This is what I have to do.
In /etc/firmware
1. copy nvram_AP6335.txt to /sdcard
2. Rename nvram_AP6335.txt to nvram_AP6335.txt.orig
3. Rename nvram_AP6330.txt to nvram_AP6335.txt
4. Reboot
There are currently 2036 users online. 4 members and 2032 guests.
