check the first post and download the flashtool, it includes instructions (it is windows software).
Lollipop - Wasser Firmware for Beelink R68 with Gigabit LAN, WIFI AP6335
Originally posted by musakilic View PostPls can anyone help me about wasser firmware..
i have geekbox but dont like firmware and i want to install wasser firmware but not work how can install wasser firmware
So if you use a different ROM those things won't work.
Originally posted by wasser View Postversion 3.1.2- built from lollipop 5.1.1 SDK
- firmware based on release-keys instead of test-keys to improve app compatibility
- rooted
- unified storage (emulated SD)
- youtube 1080p/1080p60fps support
- netflix support
- init.d support
- multiuser support
- nfs filesystem support
- exfat filesystem support
- ir remote full support
- add hardware keyboard menu
- add longpress menu key to show/hide navbar
- add power off button in navbar
- add sleep, reboot into recovery, reboot into bootloader in menu
- add support "dont wake up devive with mouse movement in suspend mode"
- add new mouse pointer
- fix usb sound issue, microphone issue
- fix wake up issue in sleep mode by the stock IR remote
- fix random ethernet MAC adress
- improve UI and video streaming
- fix some isssue in launcher3 and improve system performance
- fix read/write permission for storage
- improve IO performance
- update google apps
- update busybox
Firmware download: wasser-firmware-lollipop-3.1.2-i68-1000lan-rk3368
Wasser Kodi-15.2 (auto refresh rate switching, rockchip codec, passthrough) download: wasser-kodi-15.2-lollipop
Updating instructions, updating tools and drivers download: flashtool
Please report feedbacks so i can improve it in future release. ThanksBe aware: it is your own risk!
Geekbox uses different wifi, LED lights & shutdown.
Pls help me how can i change kernel or other thing
Originally posted by surow View PostHi! Established firmware - WiFi doesn't work (Beelink i68 1000m)
I Have as well Beelink i68 1000M ( from Gearbest ) and have the same issue. I don't understand why the firmware supposed to be for " NEW - Lollipop - Wasser Firmware for Beelink i68 with Gigabit LAN
" didn't work correctly. Is it for AP6330 or AP6335 or something else?
Originally posted by wasser View PostHi all,
I have built new wasser kodi 15.2rc2 which should fix the passthrough and 4k video streaming. It's a big improvement in this version. Please take a look at the first post to get the Download URL, Please test it and report the feedbacks
Thanks,
Wasser
hi wasser, i would like to test your kodi version, but the pvr add-ons are not included, these add-ons are included in official releases and no where else to find, at least i cannot find them after few days looking for them, is there a chance that you provide a version with pvr add-ons included?
or does anyone else knows of a repository that includes these add-ons, or a way to install the official repository, i really, really cannot find it...
big thanks in advance!
if you like me are new to this world of android tv boxes, then you probably do not know of this nice project SMPC http://spmc.semperpax.com/ it is a fork of kodi for android, give it a try, it contains several improvements for rockchip based boxes.
i also got official kodi 15.2 to perform ok for me making audio output fixed.
Originally posted by wasser View PostHi all, lollipop wasser firmware version 3.1.3 for Beelink i68 with Gigabit LAN is released. For more infos, please take a look at the first post.
Enjoy and don't forget to post feedbacks
Wasser
Can you provide any tips on how to use built in IR?
Wasser
hi wasser please, please, can you tell me what do you mean with "ir remote full support"? which ir protocol is used by this box? big thanks in advance!
There are currently 2034 users online. 1 members and 2033 guests.
