NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Originally posted by jagr View Postunable to download. any mirrors? 1.7 is also downPlease consider making a Donation to freakTab
Originally posted by big10p View PostYes, it is strange but it suits me fine as I wanted to clock mine up to 1.6ghz, anyway.I just thought I would mention it in case some folks weren't aware of it.
I should get some cooling installed on my MK809II in the next week, but until then I'm just using CPU Master to regulate it down to 1.2Ghz, max.
Originally posted by atomwood View Postmy wifi is working fine. I am using this on the mk809ii. Much smoother than the imito release. XBMC streaming HD video flawlessly.
Antutu did crash when trying to run test. That is the only thing I have noticed thus far.
I have Measy RC11 - will it work ?
Is there a newer version of Finless ROM 2.0 ?
Does it work with EXT2, EXT3, EXT4 partitions ? I mean format my entire card like that, not for Link2SD, but for faster transfer speed.
Is there a way to download / save / get the original stock Android 4.1.1, in case of problems ?Last edited by queensoft; 24 February 2014, 20:33.
Originally posted by salundy View PostSurround sound with all RK3xxx chips is not possible. In the CPU is missing a specifically layer for that. So this is not a software issue.
Gesendet von meinem GT-I9100 mit Tapatalk 2
Originally posted by astomaz View PostHi!
I have a Ditter V12 and i'm using Finless ROM 2.0. This is the only ROM wich the WIFI works, but if i restart the device or turn the WIFI off, it doesn't work anymore, so i have to do a reset factory and then the WIFI turns on again.
Any suggestion?
RK3066 + MT5931SA + MT6622N
I wonder why Finless took it out
Originally posted by Pax View PostYes, you have to delete the data/misc/wifi directory and replace the wpa_supplicant.conf file with the default one in the system directory, manually adding your network and pasword to it
It didn't work. Still not possible to turn the WIFI on after turn it off or restart the device. After a factory reset, the WIFI returns to life.
Originally posted by Pax View Postby the way, I just tried again with another ROM which has the passthrough and it works perfectly --- too bad it doesn't support my wifi because that ROM is really perfect (Rikomagic MK802IIIS8G)
So your saying you have an Mx1 and installed a rom and Passthrough worked?
What rom is this?
AW: NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Please tell me what rom you have tested? I tried on my UG007 (the same like imitio mx1) all roms (1.x and 2.0). Nothing of those could play 5.1 surround. The only what works is a downmix to 2.0 stereo, but no real 5.1/7.1 .
I planned to make an init.d for it but after I manually replaced the conf file with the one reporting "MTK" and manually added my network it was working and autoconnecting on boot
Originally posted by reddragon72 View PostSo your saying you have an Mx1 and installed a rom and Passthrough worked?
What rom is this?Originally posted by salundy View PostPlease tell me what rom you have tested? I tried on my UG007 (the same like imitio mx1) all roms (1.x and 2.0). Nothing of those could play 5.1 surround. The only what works is a downmix to 2.0 stereo, but no real 5.1/7.1 .
it would be wonderful to get it working with my wifi! (I have the Cozyswan MK809-II 4.2) It has not only the passthrough, it's smooth and has big scaled fonts and icons like the 720p but at 1080p instead!
There are currently 3815 users online. 1 members and 3814 guests.
