Enviado desde mi GT-I9100 usando Tapatalk 4 Beta
NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Re: NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Originally posted by morias View PostTry reflashing.
Sorry about this but I've started a thread asking why I can't install 4.2.2.
My pc - windows 8 tells "driver software is upto date" and the laptop - Windows 7 syas that windows encountered a probleminstalling the driver software for your device. Driver is not intended for this platform.
Can you help please?
Bob H.
p.s. I'll try to withdraw the new thread.
Well I finally got into Flash mode - in the end I was reinstalling Windows on a crappy old laptop for a neighbour decided to try the MX2 and it worked - could never install the drivers or get Windows to see the device properly on newer machines!
I really like it, obviously it is worth having a decent power source or the machine just doesn't function properly!
One question - I have a 16gb Micro SD that used to be usable on the MX2 but now with Finless although Android can see it's size it can't write to it - says it is full... I've reformatted to Fat32 on my PC and it seems fine, Android creates a LOST folder but then when I try and move apps to it, it just complains it's full - when it's far from it!
Any ideas?
Unfortunately like many 4.2 roms this doesn't work with plex.
I think only the custom rom by strauzo for the t428 works perfectly with plex.
Which of course bites since you either use a older rom with possible flacky wireless or a new rom but use a external play to get plex to play media.Mk802IV Neomode 1.9a original rom 720p
Any Bluetooth fix?
Wondering if anyone has figured out a fix for the unstable Bluetooth connection - when paired with a stereo Bluetooth headset, connection drops every 30 seconds or so, and if you are watching a video, it crashes the video player, too!
Surely, I am not the only one who loves to stream audio over Bluetooth!
I remember a post by Bob, where he said Rockchip is aware of this iissue, and is working on a fix. Hoping they have fixed it by now...
Thanks!
Originally posted by Finless View PostFor this release I have touched NOTHING to do with how well Wifi works over the stock 4.2.2 ROM Imito released.
If your having issues then you would have had the same issues using the stock 4.2.2 released from Imito.
But, trust me... They changed how wifi works in the stock 4.2.2 ROM (way different than previous Imito Stock ROMs) and I do not like it myself.
While I have not had an "user" issues myself with it (works great for me), I do not like how they technically implemented it.
So is there problems? Well I am not seeing it myself because I pulled the stupid crappy antenna from my case and leave it hanging outside, but could it be worse if your antenna is still in the case? Sure it could but I do not know that since wifi for me never worked good until I pulled the antenna from the case.
Normal apps using wifi act normal. So are there any settings to make adjustments?Last edited by josvl_52; 30 July 2013, 16:32.
There are currently 2362 users online. 2 members and 2360 guests.
