Unless you use a Launcher that will do it.
NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
go launcher HD
Originally posted by socialexandru View PostYeah I know I wish didn't install again other launcher. I use Nova usually and TV launcher but sometimes is a pain in the a** so I was thinking to keep only the standard one. Thanks anyway ;-)
Enviado desde mi GT-I9100 usando Tapatalk 2
Originally posted by Finless View PostCorrect. 4.2.2 change HDMI output in some way. Not by Imito but by Rockchip. All TV sticks with 4.2.2 have this issue with some TVs. All my TV seems to work though.
So not a stupid suggestion but a smart observation.
Hi Bob,
I'm back on Finless 2.0 with 4.2.2. and it's working now on my 7 years old Samsung Plasma.
I knew my PC screen worked with it, so I updated on that. After the update I brought the HDMI resolution on 1280X720p - 50. Plugged it out, plugged it in my Plasma and guess what? BEAUTIFULL BOB'S FINLESS 2.0 on my screen. So the problem was the HDMI resolution in Settings - Screen - HDMI Mode.
I got the idea, when I plugged my Pipo M9 with 4.2.2. in my TV and didn't get a screen. So I changed the HDMI resolution also on 1280X720P and did get a screen.
So this problem solved and hope it will work for others too.
Originally posted by cbd View Postmy mk809ii sometimes freeze's and restarts with this rom, the mk809ii reaches a very high temperature, is there any solution for this?
Enviado desde mi MK809II con android 4.2.2
As I understand things, this ROM will allow the device to run at 1.6Ghz, which without any cooling could fry it.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
Originally posted by m86356 View Posthi
I have 1.7 version and wanted to upgrade to 2.0
I tried to flash the new software..
but it didn't work.!!!!
RKAndroidTool has finished the flashing operation and the imito mx1 rebooted
but the screen stopped with the message:
Recovery system v4.2
Formatting /data...
with the android green symbol..
anybody can help please...
After reboot it should boot up the 2.0 ROM.
Hope this help.
Re: NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Originally posted by bluesmanuk View PostUse an app such as No-Frills CU Control to throttle it to 1.2Ghz.
is the same in stock rom...
Enviado desde mi Xperia Arc S
Cpu pro
the stock 4.2.2 is running @ 1.6 thats strange .
it means u frie your cpu when you upgrade?
Originally posted by benster1 View PostI use CPU pro to clock it to 1,4 I think thats ok.
I use only 2 minutes the stock rom is short time to make conclusion in stock rom.
sorry for my english ;-)
Can't switch user!
Hi!
I tried to test the new 4.2 option of having multiple users. I did it because I wanted to try some XBMC builds without having to uninstall XBMC every time etc. Anyway, I added a new user and after a reboot, for first time I saw a lock screen on my iMito MX1! Then I unlocked the screen and I was on the new user's home screen. Everything was ok but the problem I have is how to switch back to first user. I rebooted the device, I was again in my first user's screen but now I can't go to the second user's screen! Maybe the problem is that there isn't any option to go to the lockscreen. Has anyone succeeded in doing this?
I think it's more the case that whilst the device may be marketed for use at 1.6, it might just not be advisable.
At least if you throttle it back to 1.2 or 1.4 and test, you may quickly be able to eliminate things until you get to a satisfactory answer and solution.R-TV BOX S10, Beebox N3150, Chuwi Hibox, Nvidia Shield, A95X Max
I'm having an issue with VPN, using the original android VPN connection and an applicaton called VpnROOT, my VPN connection to my home network keeps dropping every 10 minutes. It works for 10 minutes, then reconnects in around a minute and then drops again in 10 minutes. Is there anyway to fix this?
There are currently 2323 users online. 2 members and 2321 guests.
