NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Originally posted by xDeepS View PostWhy does Netflix look like this when playing on v2? Works fine on v1.7. Latest Netflix app.
And my VPN app doesnt seem to work either. I use PrivateInternetAccess app and it works on v1.7 too.
You can get netflicks working if i remeber correct by using the one posted in the first post of this thread.
Its a older version of netflicks.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View PostNetflicks doesn't work on any of the 4.2 bins except the 1080p one from rikomagic but that bins full of bugs and causes overheating.
Are people still complaining about Netflix and android 4.2? This is old news, use Xposed with the Netflix patch and you're done.
Everyone should have Xposed installed anyway to plug the two Master key exploits discovered recently.
Xposed: http://forum.xda-developers.com/show....php?t=1574401
Master Key Dual Fix Module: https://play.google.com/store/apps/d...ydualfix&hl=en
Netflix 4.2 Fix Module: https://www.dropbox.com/s/d5ifqqwh0z...round-Dinc.apk
The Netflix fix says it is for CM10 but works fine on other roms as well.
For those not sure if their device is still vulnerable to the Master Key vulnerabilities, you can install Bluebox Security Scanner from the Play Store. Then run it again after using the Xposed module to fix it to make sure it is patched: https://play.google.com/store/apps/d...onerootscannerLast edited by Jbardi; 05 October 2013, 06:46.
Originally posted by Jbardi View PostAre people still complaining about Netflix and android 4.2? This is old news, use Xposed with the Netflix patch and you're done.
Does anyone know a fix for xbmc hardware support to play hd content smoothly? Steaming 1080p movies from my media server works fine using other apps but not xbmc.
CPU frequency/temperature question
First of all thanks for your work Bob.
I flashed your Finless ROM 2.0 (kernel 720p) on my UG007. In stock rom I have problems with some movies but yesterday I watch 2 of them with no problems. Thank you again for your work.
I read here that this kernel unlock CPU frequency up to 1.6 GHz and I need passive cooling. As I say yesterday I watched 2 movies without brake (not full HD). All the time the device was cooler than with the stock rom so for now the CPU frequency is not 1.6 GHz or closer I think. Is there a way to monitor cpu temperature (like sensors command in linux) and frequency (like cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq in linux). I do not want to add passive cooling if there is no need of it.
video issues
Tried installing 2.0 on a pair of MX1s, with the 720 video. They would work on my samsung LCD but when plugged into my amp and older 56" 720p rear projector TV, no video at all. Went back to 1.7a@720p, no issue at all on the big old tv. Strange.
2.0 also drove me crazy with this constant black screen flickering. Every time I'd click the mouse, the screen went black for a second. Very bizarre but not present with 1.7a.
Am I the only one experiencing this?
There are currently 1713 users online. 1 members and 1712 guests.
