NEW - Imito MX1/2 JB 4.2.2 - Finless ROM 2.0
Originally posted by yasi View Postno i've got a looping boot screen :'(, but it seems that few guys got it working on imito and ug.
Then use Finless's flash tool but be sure to clear the memory first.
Most MX1 boot loops are from a corrupt NAND memory.
Originally posted by reddragon72 View PostFind the thread for breaking out the individual IMG files within the main file.
Most MX1 boot loops are from a corrupt NAND memory.Cozyswan MK809II - 4.4.2
Vega S89 Elite - 4.4.4
Hi guys need your help desperately. I have a mx box (diaotec) that shows no source on the tv screen it got this way after a firmware upgrade. A light blue light comes on when the box is plugged in but there is no response when the remote is pressed. I cannot even get into recovery mode. Specs
Model Number:IPTV 18 Pro/GBOX MX2 Solution: Amlogic 8726 MX Dual Core Cortex A9 Neon XBMC: XBMC Frodo Preinstalled System: Android 4.2.2 Jelly Bean Smart TV Box Mini PC: Android Mini PC on Your HD TV Game: Android Game Player Ram &Rom: 1G Ram and 8G Rom HD: 1080P and 720P re are the specs:
HI , i just bought the Imito MX2 . It's working really well.
Btw , is there any way to play a slideshow/video automatically from this imito to TV set without any configuration in the first time ?
So when the TV turned on and switched the source into imito it automatically runs the slideshow
Thank you so much for the help
Hi I have IMito MX2
I currently have Finless 1.5 rom setup on it. I have tried to get the device into recovery mode, but nothing works.
I have tried the Pin reset, but it always boots to Android logo with Red Triangle.
I have also done reboot recovery from a shell command and again always boots to Android logo with Red Triangle.
This is the same when I user the recovery app from app store.
I am trying to get Finless 2.0 on, but cant get passed the first hurdle. Anyone got any Ideas?
Also tried the below...
I have windows 10 x64 Pro. The device detects in RockChip Batch tool, but when I press Switch, the driver shows up in device manager, but with a problem, I have installed windows 10 drivers but get error that best drivers are already installed. Also I have disabled driver signing but no joy
There are currently 2026 users online. 0 members and 2026 guests.
