By all means, everyone's welcome to try these builds
/dts-v1/; /// ***************************************************************************************\n //$$ PROJECT="meson8m2" //$$ REMOVE 1 void root_func(){ //$$ ADD /{ amlogic-dt-id = "m8m2_n200_1G"; compatible = "AMLOGIC,8726_M8M2"; model = "AMLOGIC"; interrupt-parent = <&gic>; #address-cells = <1>; #size-cells = <1>; /// *************************************************************************************** /// - CPU //$$ MODULE="CPU" cpus { #address-cells = <1>; #size-cells = <0>; //$$ DEVICE="cpu0" cpu@0 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x200>; }; //$$ DEVICE="cpu1" cpu@1 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x1>; }; //$$ DEVICE="cpu2" cpu@2 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x2>; }; //$$ DEVICE="cpu3" cpu@3 { device_type = "cpu"; compatible = "arm,cortex-a9"; reg = <0x3>; }; }; /// *************************************************************************************** /// - Cache //$$ MODULE="Cache" //$$ DEVICE="cache" cache-controller { compatible = "arm,meson-pl310-cache"; reg = <0xc4200000 0x1000>; arm,data-latency = <3 3 3>; arm,tag-latency = <2 2 2>; arm,filter-ranges = <0x100000 0xc0000000>; cache-unified; cache-level = <2>; aux-instruction_prefetch; aux-data_prefetch; aux-ns_lockdown; aux-force_no_write_alloc; aux-cache_replace_policy_round_robin; aux-early_write_response; aux-full_line_of_zero; aux-ns_int_ctrl; aux-share_override; prefetch-double_line_fill; prefetch-prefetch_drop; prefetch-prefetch_offset = <7>; }; /// *************************************************************************************** /// - Memory //$$ MODULE="Memory" //$$ DEVICE="memory" //$$ L2 PROP_U32 = "aml_reserved_start" //$$ L2 PROP_U32 = "aml_reserved_end" //$$ L2 PROP_U32 6 = "linux,usable-memory" memory{ device_type = "memory"; aml_reserved_start = <0x06000000>; /**reserved memory start */ aml_reserved_end = <0x05000000>;/**reserved memory end */ phys_offset = <0x00200000>; linux,total-memory = <0x3fe00000>; //$$ DEVICE="mem_4k2k_decoder" //$$ L3 PROP_U32 2 ="reg" mem_4k2k_decoder: region@1 { region_name = "cma_4k2k"; linux,contiguous-region; reg = <0x00000000 0x0c000000>; }; cma_0:region@0 { region_name = "cma_0"; reg = <0 0x01200000>; linux,contiguous-region; }; }; ///
There are currently 1986 users online. 1 members and 1985 guests.
