Maybe this help developing mxiii-g
[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Originally posted by Mati-PL View Post
Well, my box will be used for watching movies stored on Network Disk. So mainly I need is smooth playback 1080i movies (in HEVC included) and cec support.
Originally posted by envagyok
Mxiii-g with OE can play bd 3d iso?
Originally posted by ChrisR132
Hello,
I have the MXIII + from tronsmart is there a way to install this and keep android 5.1 on sort of like a dual boot? So when I start up I can pick this or android? Thanks
Originally posted by 87danp
i can flash back to android after the op installed, right? like the updates from TRONSMART?
Originally posted by envagyok View PostHere's wetek core (s812) openelec:
Maybe this help developing mxiii-gOriginally posted by rfcap78It would be great if the openelec for MXIII-G would be based on wetek core release.
Thanks for your efforts.
Originally posted by wilro_6276 View PostHowdy All,
My ongoing tests in improving stability with this rom has taken me back to looking at the bootloader (again!) - One thing has become very clear here, the bootloader we currently use (316k4 android 4.4.2) is as buggy as anything, whereas using the latest LP bootloader (106L1), stabilises just about everything EXCEPT it breaks all hardware based video decoding
My testing shows that when using software only video decoding, everything except x265 (& prob. 4k stuff) run far better with this bootloader - Even my 40G bluray image plays faultlessly! (The box certainly gets a lot warmer, however, so clearly the box itself can handle far more with this bootloader than the original can.
What I haven't figured out is why kodi doesn't play nicely when hardware decoding is enabled (even the mali 3d stuff performs better). going through the LP android rom, I suspect it may be related to hdcp? I'm a bit lost at this point, but have a few more (time consuming) things to try/test...
Is this related to the permissions not set correctly with Kodi 15? I know the same applies with android builds 14 vs 15 and root priv.
Why are you using the tronsmart 316k4 vs the MXIII version? I have found the Tronsmart build does not work as well as the last MXIII 4.4.2 OTA 316k4.
Frank
Ok, I've installed Kszaq 5.95.5.2d and seems everything is ok. But i noticed that during kodi configuration and navigating in menu, CPU temperature oscillate in 60 celcius degree. Is this normal for nearly idle mode ?
And other problem - how check ethernet or wlan mac address, without using ssh ?Last edited by Mati-PL; 14 December 2015, 22:07.
Originally posted by MinixCrazy View Post
Wilro,
They've actually changed the whole way sdcard based recovery works in lolli, the new recovery claims it can't "find" the MISC partition on the EMMC, when trying to install OE, despite the fact that it's there.
Using the old recovery allows me to flash the new bootloader without error, however, kodi's display locks/stutters when the hardware decoding is enabled (software decoding works really well)
I'm hoping I just need a minor tweak in kodi/bootup to fix, but I suspect it may be related to hdcp or some lame attempt to stop anything non-android from working on these boxes - It'll be interesting to see if anyone can get OE working with the newer chips (S905/S912?), as this will no doubt provide a clue as to what's needed to work around the problem.
Frank- I'll try changing back to the MXIII-G one on my next build...
Originally posted by Mati-PL View PostOk, I've installed Kszaq 5.95.5.2d and seems everything is ok. But i noticed that during kodi configuration and navigating in menu, CPU temperature oscillate in 60 celcius degree. Is this normal for nearly idle mode ?
The mac addresses show under the system status/network when connected (well, they *should*
I've bricked my box doing something stupid, and now i can't seem to be able to unbrick it
Basically trying the toothpick method i get stuck in the android recovery screen where i can choose between updating from sd or usb between other options, but choosing one of those when i browse to the device it always shows up empty? I've also tried adb side load but i get an error about the package not being signed. Any suggestion on how to save my box or i just have to put it in the special waste bin?
i've attached an example of the screen i'm stuck to when using toothpick trick (the picture is not mine so don't mind about the error message)You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by ilfrance View PostI've bricked my box doing something stupid, and now i can't seem to be able to unbrick it
Go to this site :
Download the burning tool + the .img file - follow the instructions on the page.
I use my phone's usb cable to connect the box & it has worked every time when I've screwed up the bootloader (getting the tool to "see" the MX3G may require a few attempts
Originally posted by wilro_6276 View PostI've had to do this quite a few times:
Go to this site :
There are currently 2426 users online. 0 members and 2426 guests.
