[ROM] Unofficial OpenELEC for MXIII-G & Tronsmart MXIII+
Originally posted by baalho View PostIt was probably my fault.
I actually booted directly to stock recovery and did the install zip from EXT.
My SDcard reader in computer is broken, so I put the zip file in a usb and tried to flash it.
So I actually need to extract the zip file to the root of the SDcard?
Was was surprising was I was able to flash the old build with out the signature problem. Any thoughts wilro?
I have tried every flavour of android 5's (both MX3G & Tronsmart MX3+'s) bootloader/recovery + combinations/mixtures of both, & get the same error you're getting in every case.
With the exception of minor build tweaks/updates, I use the toothpick method to ensure I have a "clean slate" for testing my builds prior to release (time permitting, of course
Originally posted by MinixCrazy View PostWilro, Great job on the ROM. I'm running your 6.0e and haven't experienced any issue for over 24hrs. CPU control is great, all videos are being decoded via hardware and I've had no trouble with Wi-Fi even with my static settings using alternate DNS servers. I've updated all three of my boxes with a fresh install and all have been flawless and fast!
Have you thought about a list of changes for each revision?
I actually reserved the 2nd post in this thread to be able to document the changes - Now that I've finally reached a fairly stable state with this box (6.0.0e), I will endeavour to document future releases from this point.
Speaking of which, after another 16hr marathon (30+ builds/flashes) - The wife/kids are gonna kill me, this isn't the time of year to be dabbling with my "gadgets", I believe I've finally nailed the Android 5 bootloader issue. My next build will be more stable & truely show how much better OE can perform on these boxes compared to the stock android 5 (I still have a few niggles to address - Ironically, they are mostly the same as what we had with the original kamak build that started my interest in fixing these boxes - It's just my fixes don't fully work with this new build
And where is the PayPal link for
Originally posted by wilro_6276 View PostThese builds are derived from the efforts of many, my thanks to all concerned, & esp. Codesnake for making OE a viable option on Amlogic based devices - Without his initial port, I wouldn't be here trying to improve support for the MX3G
My goal is to improve/refine OE support for the MX3G, my builds are derived from Kszaq's & Kerber's git forks, however, I also cherry pick other branches & add a few tweaks of my own for good measure.
I currently have 3 builds for this device:
My builds (Codesnake based, best bits from Kszaq/Kerber):
Toothpick Install (zip)
Openelec update Install (tar)
I have an MX3 2GB version with S812 processor. I have downloaded the zip file, and have extracted the contents (3 files) onto an SD card and installed this onto my box. When I do to the toothpick install, I get to the "green man", I let go of the tooth pick and power button and it seems to install (ie the progress bar fills up)
It then reboots, and now is frozen at the OPENELEC screen
I have done this over and over
Do you know how I can fix this and why this is happening?
Originally posted by tb82 View Post
tb82,
You might have corrupted install files. Reformat the sdcard, download the zip again, extract and try again. I've just tried all three downloads and they work.
Frank
Originally posted by red1928 View PostAnyone using openelec on Tronsmart mxiii plus 1gb? Is it OK to use twrp to install this version of openelec on it?
If your device is currently running android 5+, then it must be installed via toothpick/sdcard (TWRP can then be reinstalled) - This build depends on an android 4.4 based system at the moment.
Do you know how I can fix this and why this is happening?- Once you have OE able to boot, you can use the .tar upgrade file to try this version.
Hi wilro, thanks a lot for your hard work in porting openelec to the MX3G. I have a kinda offtopic question, that is: how hard would it be to port arch linux arm to the MX3G? There is already an s805 port made for the ODROID-C1, would this make it any easier?
Thanks in advance for your help!
Hello wilro, almost all of my SD movies stutter,. With or without hardware decoding.
I play the files from a NAS.. I have no problem with hd movies from the same NAS
And when i use hardware decoding (Video: MSMPEG4v3 1024x576 25fps 1998kbps [V: msmpeg4, yuv420p, 1024x576, 1998 kb/s]
Audio: MP3 48000Hz stereo 128kbps [A: mp3, 48000 Hz, stereo, 128 kb/s]) video does not play.. only audio.
your build an kerber's build has this problem.. I dit not test the 5.95.5 build
Do you have any idea what i can do?
Originally posted by ricpersi View PostHi wilro, thanks a lot for your hard work in porting openelec to the MX3G. I have a kinda offtopic question, that is: how hard would it be to port arch linux arm to the MX3G? There is already an s805 port made for the ODROID-C1, would this make it any easier?
I doubt it would be too difficult - The biggest issue is dealing/patching around the quirks in the MXIII-G itself. My main interest in dual boot on this box is to run OE/Arch (already do it on my MXQ/MK808b- Failing a proper dual boot function for this box, I will probably roll my own poor mans solution (ie. use a common boot kernel for OE nand/Arch SD
- There are still a few show stopper's for me on this box at the moment, before I start exploring the more "fun" things like this, however.
Originally posted by nighthawk1975 View PostHello wilro, almost all of my SD movies stutter,. With or without hardware decoding.
Unfortunately, I don't think this old non-standard video format is supported by anything except windows itself. I vaguely remember reading about a tool that could losslessly convert these to standard divx4/mpeg4, but that was an awful long time ago now ;(
The hardware decoder's from what I can tell, only handle the standard mpeg video/audio formats, everything else is left up to software decoding (ie. ffmpeg) - Unfortunately, it looks like not even ffmpeg can handle this particular format (or it's too demanding on the amlogic CPU). Other's may have a better insight to this than I - I've never used any video/audio formats that have MS or Apple in their names
There are currently 2016 users online. 1 members and 2015 guests.
