My Netflix expired so I have to get a trial account again and use a VPN service to test which is a bit difficult, but will do if someone else doesn't test it in the meantime.
HPH RK3288 Lollipop ROM v1.3 by mo123(Light Biz OS)
Please test this Kodi.
Uninstall NTMC.
To reinstall the NTMC, you can go to /system/preinstall/NTMC
I'm also working on a new Kodi 16 and Rockchip already released new pass-through patches, so I'll see if I can get that going also, but I'll have to rebuild the ROM and first upload it as a test ROM.
Thanks for the info! I've given the RockChip Kodi from the link you posted a go, and also tried the latest Kodi 16beta4 . I seem to be getting the same behavior more or less, don't know if it's kernel or kodi related.
I have the Android environment audio device set to hdmi bitstream, and the Kodi audio settings set to no keepalive / passthrough on / ac3 on / dts on
When I play a MKV movie file with DTS-HD MA 7.1 audio track, it gets passed as a 5.1 track with 'fltp', and the receiver goes into 5.1 mode , but no Master Audio makes it through.
When I play a MKV movie file with Dolby True HD 7.1 audio track, it gets passed as a stereo track to the receiver. The audio plays fine, but on 2 channels.
each time I initiate playback, I do see the receiver renegotiating the HDMI bitstream and clicking into the set speaker mode.
The audio on the 15.2 Lollipop build you linked me to has a continuous stutter every 1/10th of a second. I can hear the audio fine, but it's sort of clipping.
The 16Beta4 release doesn't have the audio issue.
As a comparison, I have a RK3368 box running the latest Zidoo X6 Pro firmware, and on that unit, Kodi 15.2 passes the Master Audio track in DTS-HD MA, and Dolby True HD as well for the same movie files I'm using as a test. They do use a 75MB buffer (vs 10MB default I see in the other releases).
i can confirm that netflix is working (latest version of netflix from Google play); dns from https://tvunblock.com/ (no vpn needed)
thanks again for the firmware.
hello,
I installed the rom / but the OK button is not working with the default remote / with my male airmouse it is ok...
is the act firmware within the update.img file
I got the hph box apx. 1 year ago special build *first ones with 4gb memory and 32gb rom / so after one year I tried to use it for tvheadend playback but no luck...
is there something special I need to consider *put on some new firmware...
any help would be great
thanks
holli
PS / when I use the resolution for 4k 60hz I get not good picture on my 65 4k screen
Originally posted by m1pnkso im just watching tv on kodi with the new firmware.... box crashed twice so restarted.... then final crash with no power at all.... going to reinstall firmware and see ?
thanks
holli
Edit: my mele f10 deluxe remote work now after 2 restart the box
Originally posted by Shadi86 View Post
My mele f10 deluxe and the regular hph remote don't work for me
I will just check the IR Remote, but people should use an airmouse by default since it's much easier to use.
For me the screen get freeze directly when I start the box, and the nova launchers it's also not so good and it's making it worse, will switch off the DC and try again and see if any luck
There was a Chinese Launcher first included that was even more difficult to use.
thanks
holli
What DVB tuner do you have and is it included in the dvb tuner zip file in one of the posts above?
Can you get it working on your own perhaps?
I will try to add DVB tuner support in next firmware.
Glad you mentioned this new feature.
Originally posted by Shadi86 View PostWaiting your new release so I can get you feedback,
many thanks
New Kodi 16 beta 5 with Optimized Pass-Through support(Only for ROM below)
Here is the Kodi Passthrough Test ROM.
Please test the new Kodi 16 beta 5 for video playback, pass-through and with Light Biz OS
Can manually hide the status bar with the bottom arrow icon to make it fullscreen and swipe the bottom part of the screen up to make the status bar reappear.
http://www.mediafire.com/download/o1..._16_PT_Test.7z
Kodi 16 beta 5 PT
http://www.mediafire.com/download/tx...v7a-Build2.apk
1. Set Audio Output to HDMI Bitstream in Android Settings
2. Choose your pass-through settings in Kodi - Settings - Audio(enable expert settings at the bottom first)
Other people with pass-through equipment, please test the above ROM.
I want to know if it Kodi & pass-through works correctly and better than the ROM in the OP, so I can make a custom ROM with this new Kodi 16 beta 5 with optimized pass-through support.
Maybe just install a different launcher first for easier navigation.Last edited by mo123; 30 December 2015, 17:04.
Kodi 16 beta 5 PT
Will give it a try
Heya, I can't get the new ROM you link to work correctly. it flashes, and I get HDMI signal, but black screen. Nothing else. When I flash your previous ROM, the unit goes into 'recovery system 5.0' and does the update, but in this case, nothing happens. Maybe I'm not patient enough post-flash?
I will try Kodi16b5 on your previous lightbiz OS rom
There are currently 3862 users online. 1 members and 3861 guests.
