I just checked the purchase date on Geekbuying and it was 2013 & it is RK903, not a clone or variant. Thanks for your help
MK808B (RK903) KitKat 4.4.2 ROM
I have attached the dmesg from the 4pda ROM as requested. I knew the ROM/Kernel from that post wouldn't work but I downloaded all known kitkat ROM's for the device in the hopes I could get one that worked. I should also mention that after flashing the 4pda ROM, I can flash the system.img from your ROM and it will boot and work but no WiFi. If I then flash your kernel I get the 2 penguins again.
Junia .... Looks like a Realtek chip. If you open up the stick it is suppose to look like this...Last edited by rwstarke; 03-05-2016, 00:27.
Thanks for your response, I did open the device and have confirmed it is original MK808B, It was purchased from Geekbuying back in 2013. The kernel used in that dmesg is from the 4pda rom for realtek devices. At this time, that rom is the only kitkat that will boot on my device, although wifi or bluetooth wont turn on as my device is rk903.
Hello, I was looking into the issue again today when I noticed a slight variation from the pic that RWSTARKE posted.
As you can see from the picture I attached, I do have a rk903 chip and my board is the same but there is a difference in the numbers shown.
Mine shows rk903, tod1002, 1305
Yours shows rk903, tod2002, 1310
Perhaps this is the issue?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Unfortunately the new rom is still giving me 2 penguins. I have flashed it fully on 2 different machines to verify. I think it is likely a kernel problem as I get 2 penguins even if I don't flash the system image (to restore 4.2.2 I flash everything but system so I can quickly use CWM to restore a backup).
Please let me know if there's any other information I can provide that might help.
Originally posted by BalintBanyasz View PostI've built a new KitKat ROM from scratch. Link's in the OP.
I hope that it will work an all MK808B/RK903 devices. Also, make sure that you run EraseFlash before the upgrade.
Unfortunately the ROM freezes during the boot animation. I am definitely getting much farther then before as I get passed the 2 penguins without issue. I will play around over the next few days to see if I can get it booted.
BalintBanyasz - Did you change anything in the Kernel with this new ROM?
There are currently 2626 users online. 6 members and 2620 guests.
