Retroarch addon for Openelec on MK808B+ and MXQ
Originally posted by niabi View Post
Yes, updated the binary, and all the cores, and re-added the databases and overlays
It seems like it.
Is there any setting i need the change so display is normal like we used to see in those old days ,i think it retroarch setting?
Any rom i choose graphics is so zoomed in and text are even hard to read.
This issue only when rom displays in tv ,retroarch screen is ok.
Any advise.
Originally posted by jackmate View Post
Most rom i play ,it appears zoomed in and graphics is so blurry,for eg jungle book game,prince of persia etc .
Any advise.
Originally posted by scottmu64 View Post
Are you able to explain briefly how you did this? I am aware of how to copy the cores over but don't know how to do the binary, databases and overlays? Any help would be appreciated
The folders are as follows:
Cores: \SYSTEM\usr\lib\libretro\
Retroarch Bin: \SYSTEM\usr\bin\
then I added most of these to the \emulator.tools.retroarch\resources folder in the addon.
Databases: \SYSTEM\usr\share\libretro-database\
Assets: \SYSTEM\usr\share\retroarch-assets\
Shaders: \SYSTEM\usr\share\common-shaders\
Overlays: \SYSTEM\usr\share\retroarch-overlays\
Video Filters: \SYSTEM\usr\share\video_filters\
Gamepad Auto Config profiles: \SYSTEM\etc\retroarch-joypad-autoconfig\
You also need to update your config file in emulator.tools.retroarch\config to add the paths, you could also do this after you install the add-on.
Needed Libraries for emulator.tools.32bitlibs: \SYSTEM\usr\lib\
libavcodec.so.57
libavformat.so.57
libavutil.so.55
libswscale.so.4
libswresample.so.2
ld-linux-armhf.so.3
(most of this have a different name that you have to rename, e.g. libavcodec.so.57.48.101 rename to libavcodec.so.57)
Once this is done you need to uninstall the old version, and just re-add the addons
hopefully this can help you keep retroarch up to date
I noticed there is a nightly Odroid C2 (which uses a s905) version of Lakka, but I haven't tested the bins or cores from it yet.
I also have a zip file available with all these changes, but as I said earlier I am not sure if I can share it, since I didn't really change anything to the code.
and as for the N64 part, oncer you update the cores and bin just run yur games with Glupen64, they run way better
Any advise.
No i havent,i have integer scale as on too,same issue too much zoomed in in game.
The only thing I can think off is that you had a leftover config from the pas addon and maybe there was something different there.
also what emulator gives you that problem?
Scale integer needs to be off.
I am using rompacks from https://nicoblog.org/rompacks-romsets/
I dont choose emulator,have scanned rom folder and choose from playlist.
But all roms i choose are like that.
Can it be rom itself ?
Any rom i play ,screen is zoomed in and text in game can hardly be read.
Basically just download the Lakka Odriod C1 release, uncompress everything with 7zip, first the .img, then the 0.fat file, then SYSTEM.
libavcodec.so.57
libavformat.so.57
libavutil.so.55
libswscale.so.4
libswresample.so.2
ld-linux-armhf.so.3
Thankyou for all the info. I updated the cores and now using Glupen64, unfortunately some games still run really badly but ALOT of games that wouldn't run properly before now play very well at a solid 30fps.
The PSP emulator is still slow :/ I was trying to make the standalone version run, but I get an error about display :'(
EGL Error: Unable to get display!
Even when scale integer is off.its a fresh install with new addon u supplied.
Well even if its playlist it will still tell you which system the ROM runs on . Can you post an image of your video settings?
Junglebook using nestopia emulator
There are currently 1585 users online. 9 members and 1576 guests.
