Retroarch addon for Openelec on MK808B+ and MXQ
Originally posted by vashwood View PostMust have been a bad transfer. I transferred the original files and updated them through SSH. Now XMB loads. It doesn't look the video below, but I figure I need to play w/ the config file.
https://www.youtube.com/watch?v=o8tClEmpE8c
I use the "Retroactive" XMB theme with menu animation. If you use the CEC daemon that Kszaq released you can launch and play games using your TV's CEC remote....Then just exit retroarch and you are back to Kodi.
You need the updated Assets.zip file found here :
extract it, make sure your retroarch.cfg is pointing to the correct locations, and then you will see all of the icons available...If your theme does not contain all of the icons you can "steal" them from another theme via copy\paste.
Originally posted by vashwood View PostAny ideas on where the bin for the newest retroarch?
Dont forget to chmod +x /storage/.kodi/addons..../bin/* the new binary
There are currently 1948 users online. 2 members and 1946 guests.
