Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
Thank you balbes150 for your hard work and RISCy for the detailed instructions.
I installed Odroid on a 32GB SD card on my Telos and so everything is working well as you have explained. The boot is super fast and the system snappy. I took the USB Wireless key (from my Raspberry Pi) and plugged it in Telos and got WiFi working for the moment. I was able to set English as the main system language without any hassles.
I have one question though. Oddly, the sound is not working for me. Absolutely no audio output via HDMI. Is that normal for this build? Could you please help me out with this?
Also, how do I change the video output resolution to 1080p/4K?
Thanks in advance.
for the HDMI sound issue, try this :
su -c 'echo "audio_on" > /sys/class/amhdmitx/amhdmitx0/config'
be sure you compiled the kernel with the M8 audio driver... and check the /etc/asound.conf
for the resolution, I had to change the s905_autoscript.
you are lucky for the wifi ... I have more troubles with broadcom chip of my MiniMX.
Thanks Koxx. Can you elaborate a little on how to compile the kernel with the M8 audio driver? I have absolutely no idea about compiling kernels. About the WiFi, I did not enable the internal WiFi module. I just plugged in an external USB Wireless-N adapter, which I was using on my Raspberry Pi previously, and plugged it in the USB port of the Telos. It worked straight out of the box, so to speak, no tinkering was needed.
Originally posted by rockthegod View PostThanks Koxx. Can you elaborate a little on how to compile the kernel with the M8 audio driver? I have absolutely no idea about compiling kernels. About the WiFi, I did not enable the internal WiFi module. I just plugged in an external USB Wireless-N adapter, which I was using on my Raspberry Pi previously, and plugged it in the USB port of the Telos. It worked straight out of the box, so to speak, no tinkering was needed.
cat /proc/asound/cards
if it's not empty, it's ok, you don't need the rebuild the kernel, it's only configuration (asound & hdmi).
in /etc/asound.conf, you can use this :
pcm.!default {
type hw
card 0
device 1
format S16_LE
ctl.!default {
type hw
card 0
for the wifi, I understand
Originally posted by JonSmith View PostI've been poking around in the Odroid C2 kernel config and it looks like SDIO wifi support is not enabled, which would probably explain why the wifi isn't working (I believe the wifi module is connected to the SDIO interface).
we still need the broadcom drivers & firmware... which are not included in the current 3.14 kernel if I understand corretly.
Originally posted by JonSmith View PostHas anyone had any luck getting the USB-SATA bridge working? From what I gather it's on a separate USB controller from the other 3 ports, and could possibly be initialised in USB OTG mode. I have a drive that works fine in the Android build.
I'll be investigating this myself in any case.
Originally posted by balbes150 View PostTo turn the power on SATA, you need to create a GPIO port. Using it you can operate turning on\turning off the power. I can't find the info, what is the port number of GPIO used in Telos. If you get this room, you can make expotr to GPIO and control it via the entry 1 and 0 in this port.
I'm thinking that I might be able to find which pin is toggled from android, I have root and a terminal so I ought to be able to read the GPIO when I enable and disable SATA to find the difference.
EDIT:
So far I've identified the device it mounts as here in android:
/sys/devices/adc_keypad.45/input/input1/sata_ctl
means you can echo 1 > /sys/devices/adc_keypad.45/input/input1/sata_ctl as an easy way to enable the SATA port on boot from the init.rc for android at least.
There are currently 2429 users online. 1 members and 2428 guests.
