Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
    Originally posted by JonSmith View Post
    Thanks balbes, I'll have a look when I get home.
    I'm thinking that I might be able to find which pin is toggled from android, I have root and a terminal so I ought to be able to read the GPIO when I enable and disable SATA to find the difference.
    EDIT:
    So far I've identified the device it mounts as here in android:
    /sys/devices/adc_keypad.45/input/input1/sata_ctl
    means you can echo 1 > /sys/devices/adc_keypad.45/input/input1/sata_ctl as an easy way to enable the SATA port on boot from the init.rc for android at least.
    In Openelec there /sys/devices/adc_keypad.45 but the rest of the key is missing. I'll keep looking.
      Filled with a new website image Linux - armbian.
      telos_armbian_20160506.7z
      Working with cards and USB flash drives. The password "root" - 1234. The password for the user "user" is 1. Details can be found here.
      USB troubles workaround Amlogic devices are picky on SD card brand. Expect troubles with some models.
      Use on other models standard. To replace the dtb file on your. To switch screen resolutions - copy file s905_autoscript from the folder. In the image included two options for 1080 and 720. The default setting is for 1080.
        Very nice, look forward to trying it.
        As always, Thanks.
          hi all
          Thnk balbes150 for your contribution. telos_armbian_20160506.7z
          Tried it out on a mini mx and it's working. Only i have 1 warning don't update all with the synaptic package manerger.
          you wiil completely brick your device and than you have to disassemble your box and connect pin 29+30 together of the nand flash.
          Greatings,
            Tx for this version of linux.
            I have few problem thought.
            First wireless isn't work on Telos.
            Secondly, there is no sound.
            Thirdly, why not specified this at first ?
              Thanks for your effort.Now i could run linux(armbian) on my MXQ PRO.But i noticed no gpu hardware acceleration.Is it possible especially in browser?
                Possible. Need a new dtb file with support for recent changes and possible patches to the core.
                  Updated version of Ubuntu. Now used to automatically detect the type of the model. Automatically selected the correct dtb file. It is necessary to update the multiboot. For this you need to download and run the new script. Specifically for your model. Catalog scripts with the models for Tronsmart Vega S95 is here. For use on models that are not yet included in the list of supported automatically, you need to burn as before your dtb file in the FAT partition.
                  Посмотреть и скачать с Яндекс Диска
                  Universal Ubuntu image.
                    Excellent work balbes150. Looking forward to trying it tonight.
                    Thank you.
                      with u-boot modified as described on step 1, if i put off SD Card with linux inside, i will able to boot my S95 with previous Android version installed on it?
                      Thank you.
                        Originally posted by Maurillo1960 View Post
                        Thank you.
                        When you disable a card or the flash drive, when you enable boot Android from the internal memory.
                          Hello Maurillo 1960, Welcome to Freaktab.
                          The installed Android will not be affected.
                          With SD card inserted(inside), box will boot to Linux.
                          With SD card Removed(not inside), box will boot to Android.
                          Cheers.
                            thank you for your answers! now i'm going to Linux-ize my S95!
                              Just tried this on my MXQ Pro +
                              excellent thing, shame about problem with sound
                                As a workaround, USB sound card works.
