Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
Originally posted by drakulaboy View Post
Originally posted by Jefken3 View PostWetek, is has also an amlogic chipset, they run enigma2 (openatv, openpli) it is linux based, would it be possible to compile enigma on our devices? This would be great to use my satellite settopboxes as dvb-s2 server.
https://wetek.com/blog/view/49/offic...for-wetek-play
I'm having a bit of trouble getting my box to boot. I followed the guide and copied Ubuntu to my hdd and booted the box. The T95M logo comes up on my monitor and there is a lot of hdd access for about 30 seconds, then it stops. I let it go for about 15 minutes and rebooted. It did the same thing 3 more times now.
Should I use flash media instead of a HDD? I was using my hdd since I don't have any flash drives over 4gb and all of the images are ~8gb when extracted. How can I make my own bootable img? I'd love to have a minimal Arch install. They have an Odroid-C2 build here: https://archlinuxarm.org/platforms/a...ogic/odroid-c2
Originally posted by nosmokingbandit View PostI'm having a bit of trouble getting my box to boot. I followed the guide and copied Ubuntu to my hdd and booted the box. The T95M logo comes up on my monitor and there is a lot of hdd access for about 30 seconds, then it stops. I let it go for about 15 minutes and rebooted. It did the same thing 3 more times now.
I do not recommend to use without additional training images from Odroid C2. Easy to brick.
Yeah I'm not getting this to boot at all.
I switched to a 32gb class10 micro sd card and I'm having the same problem. T95M logo and nothing else.
I did notice that in the FAT partition there is no t95m dtb, which makes sense because these images were made before I ad that, so I added it and tried again. No go. I might just buy an MXQ or something.
Originally posted by drakulaboy View Postmy box is MXIII-G , the board is Netxeon MXIII-C V1.1 S812 CPU , it only have MicroSDHC and USB ports
I made a test version of multi-boot for the S805. I think that it must be suitable for S812. But need more information on what parameters have u-boot on devices with s812.
Originally posted by nosmokingbandit View PostTried that, attempted to boot 4 times with no success. This specific device might just not be compatible for some reason.
Dear balbes150,
I have a problem with ubuntu_multi_dtb_v3_20160625.img (OpenLEC is working well). I started the system from USB drive as you wrote, but it does not update the system (frozen) and the programs boutique is not working either. Do you have the img for telos? Maybe the multi version is not ok for telos on the other hand you refer to telos version in your description. Thanks a lot!
There are currently 2736 users online. 1 members and 2735 guests.
