Running Linux From SD Card or USB Flash Drive - Using Balbes150 Method And Files.
Originally posted by desmondo View Post
Hi I did replace the dtb with the image from my own box. When you say the remote is working since balbes unified the image. The qbox has a completely different remote control to other boxes I have seen. It much larger perhaps the unified image is not compatible with the qbox remote and perhaps the bt. In oe configuration tool blutooth states not enabled.
Hi desmondo , how nice you did get OE running on your device, since yesterday I received my Q-box but native Kodi is not working like it should be so I would like to install OE aswell. Sadly enough the seller have send me 2GB+8GB instead of the 2GB+16GB I did orderd. Please could You give me some advice, any would be welcome, how did You get started? Did You have to be Root and if so, how did You have done this and how did You obtainded this dbt file...?
Thanks and regards, Jefken.
Originally posted by desmondo View PostHi Jefken3 I will prepare a guide and will upload to Qbox section later to prevent us hogging Balbes150 thread. But to start you off just now i would download the latest firmware from the Qbox section and throw the three files on sd card, i flashed this via the reset button method which can be found in the av socket at back. Simply press the button in while card inserted and box powered off, insert power cable while button still being pressed and insert power cable this starts the flashing process you can then release the reset button. Incidentally the firmware here is pre-rooted.
The same situation with multi-boot, with OE. Many of the issues are the same and duplicated.
Originally posted by balbes150 View PostPerhaps it is time to make one General topic (or group) to start Linux on the Amlogic S905. Now many of the same questions scattered across different themes and duplicated. Basic questions similar and do not depend on specific iron. Many questions are useful for other variants.
Updated Linux images (Ubuntu and Armbian). Now images support auto-negotiation dtb file. For this you need to run the TV box a new version of the script enables multi-boot. It is necessary for the formation settings, u-boot key model. Download links for new images and scripts. For models not listed, use the previous procedure. To replace the file dtb.img in the root directory.
In both images created SWAP partition. To turn it off (if needed for slow media). You need to comment out the line in fstab the SWAP.
Ubuntu is runing on my Qbox 2GB/8GB version, however the remote is not working neither my air mouse with usb, ethernet is working in my router I can see odroid64 and his ipadress...
I do have here a usb-bluethootdongle with keyboard but because I can 't reach the system I can also not pair this keyboard.
There are currently 5958 users online. 1 members and 5957 guests.
