Un Known PCB FOR 812
For one on the right use JD files for pcb with 812 and 6330 chipset sd card in this Thread http://freaktab.com/forum/tv-player-...video-tutorialMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Here is MXIII-G 4K 2/16GB. The device worked for an hour and the bricked. Now only on red light.
I've tried SDCard and USB Burning tool with no lack. My PC connects to the device, drivers seems to work. But with the SDCard method I see nothing on my TV, no recovery, nothing.
Can you help me find the firmware? Also do I need to short the NAND to wake it up?You may only view thumbnails in this gallery. This gallery has 4 photos.4 Photos
Hello, recently I bought a M8S with firmware version M8S.BCM4335.201601181037. The PCB also smaller than M8S photos posted by Meltdown. Whenever I power OFF and turn it ON the date/time will reset back to year 1980. I had tried the automatic and manual set the date/time but still same. Factory reset the M8S but still same. I think this a firmware bug and need to update the firmware but no luck. I cannot find any new firmware related to it. Any suggestion?
Thank you.You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
Hello, yes I can open a web page but with a lot of certificates error prompt out and I need to select continue before can proceed loading the web page. I think it is because of the year 1980 issue. After I change back to present date/time, the same web page just loading fine without any error.
Another error notification I found is this one.
An application attempted to use a bad version of google play services
If thats the only issue set the date and leave it on. The other option is finding an updated firmware that will work on that device (maybe manufacture?) otherwise its find similar pcb and take a chance flashing the device.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by redshift View PostAnyone found a working android image for this clone?
The motherboard says M9&M8_8bit_V1.1
The Wifi Chip is a MURATA XJ-A KM3201 (confirmed by the MAC address)
the RAM is a Nanya
Ethernet Pulse H1102NL (100 Base-T)
There are currently 3027 users online. 0 members and 3027 guests.
