Un Known PCB FOR 812
    Originally posted by DrunkSequence View Post
    Posted for info but would be great if someone could link me to a working firmware (board appears to be semi-bricked at the moment).
    Try get from here
      Originally posted by muncheno View Post
      I have worked through that entire thread but there is nothing helpful to my situation sadly.
      My main problem at the moment is getting the box in recovery mode, nothing seems to work with this hunk of junk
        For recovery look here
        Not sure T8plus will work for your too.
        Also take note there is mtd version and also EMMC version.
        Try put it inside sdcard and rename to recovery.img to boot into recovery to flash zip.
        I think you know how to boot to recovery with holding reset while power on.
          Supposedly an OTT M8S+. PCB looks almost the same as the one in this thread: http://freaktab.com/forum/tv-player-...rrect-firmware except that the WiFi chip looks different.
          Upon inspection of dmesg output while disabling and enabling WiFi I get this:
          Code:
          <4>[ 3371.050655@0] WIFI  Enable! 6
          <4>[ 3371.250486@0] sdio_reset_comm():
          <4>[ 3371.264250@0] [sdio_reinit] finish
          <4>[ 3371.364245@0] =========== WLAN going back to live  ========
          <4>[ 3371.364682@0]
          <4>[ 3371.364682@0]
          <4>[ 3371.364682@0] dhd_bus_devreset: == WLAN ON ==
          <4>[ 3371.371786@0] dhd_bus_devreset called when dongle is not in reset
          <4>[ 3371.377848@0] Will call dhd_bus_start instead
          <4>[ 3371.382174@0] dhd_conf_set_fw_name_by_chip: firmware_path=/etc/wifi/4335/fw_bcm4335b0_ag.bin
          <4>[ 3371.390672@0] dhd_conf_read_config: kso_enable = 0
          <4>[ 3371.395285@0] Final fw_path=/etc/wifi/4335/fw_bcm4335b0_ag.bin
          <4>[ 3371.401015@0] Final nv_path=/etc/wifi/4335/nvram_bcm4335.txt
          <4>[ 3371.406633@0] Final conf_path=/etc/wifi/4335/config.txt
          <4>[ 3371.504355@0] NVRAM version:  bcm94335wlcspMS_ES50_RC171p24p23_04052013_AM_mdfy_PAparam.txt -- 4/5/2013 by Murata, based on bcm94335wlcspMS_ES50_RC171p24p20_04022013_AM.txt, changed PA parameters and txidxcap parameters and ccode.
          <4>[ 3371.519689@0] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
          <4>[ 3371.653632@0] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
          <4>[ 3371.654220@0] bcmsdh_set_drvdata: Enter
          <4>[ 3371.657792@0] bcmsdh_register_oob_intr: Enter
          <4>[ 3371.662205@0] bcmsdh_register_oob_intr: IRQ=100 Type=414
          <4>[ 3371.668774@0] dhd_conf_set_band: Set band 0
          <4>[ 3371.681764@1] Firmware up: op_mode=0x0015, Broadcom Dongle Host Driver mac=00:90:4c:c5:12:38
          <4>[ 3371.684571@1] dhd_conf_set_country: Set country XS, revision 38
          <4>[ 3371.690934@1] dhdcdc_set_ioctl: msg->status:fffffffe
          <4>[ 3371.695336@1] dhd_conf_set_country: country code setting failed -2
          <4>[ 3371.702292@1] Country code: XS (XS/0)
          <4>[ 3371.705420@1] dhd_conf_set_roam: Set roam_off 1
          <4>[ 3371.724216@1]   Driver: 1.88.45.4 (r420671)
          <4>[ 3371.724216@1]   Firmware: wl0: May 18 2014 16:56:54 version 6.34.171.58.2
          <4>[ 3371.729970@1] wl_android_wifi_on: Success
          <4>[ 3371.800531@1] dhd_open: Exit ret=0
          So I'm assuming this has a Broadcom bcm4335 chip?
          The firmware currently running on this is this one: http://chinagadgetsreviews.com/downl...-tv-box-2.html
          What would be the latest firmware for this device?
            Click image for larger version  Name:	IMG_20170410_150207 (Large).jpg Views:	2 Size:	106.3 KB ID:	641856
            This M8s clone surprisingly took a 5.1.1 rom from here http://chinagadgetsreviews.com/downl...8s-tv-box.html
            The archive is aversion 3 of TWRP plus an update zip.
            Just make a boot card with that verision of TWRP, boot to it and use the install function of TWRP on the zip.
            Ethernet doesn't work but wifi connects at 65mbs.
            It seems more solid that the stock 4.4.2
              Hello.
              First Thank you for all your jobs for tv box users.
              I`m 3rd day trying to unbrick the device I have.
              It`s a RENKFORCE B4A device Chioset AML8726-M8 Amologic s812 Quad Core A9 (the info from the box ) 2Gb 8Gb
              The issue I have there is nothing when connecting via HDMI
              Installed burnning tool and connected to PC, it`s detecting as connected and seems my issue the firmware for it.
              I have tried:
              measy b4a (seems they are the same deices with different lable): http://www.measy.com.cn/download/dow...1=13&class2=51
              M8S 4k Kodi amologic S812
              and some others.
              In my case SD card method will not work, it`s not showing anything on TV
              Would be great if you can help to find firmware or help flash it with any compatible.
              Attaching images with motherboard and error which I get with burning tool.
              Thank you in advance and would really appreciate any help.
              You may only view thumbnails in this gallery. This gallery has 7 photos.
                can anybody help with this one please. its an m8s and ive been googling all day. it has a blue light when powered on but just will not connect to anything. just a blank screen on my tv and usb burning tool does not recognise it either. i have several images to try if i could only get my pc to recognise it. do i need to short the nand pins and if so does anybody know which ones because i dont know where to start. thanks for all help guys
                  Please help unbrick !!!! Tried so many firmwares already with usb burning tool but no sucess. the ouside says mkiii 4k. Inside there is a amlogic s812, a foresee emmc ,skhynix memory, and a ap6330.
                  I´ve triede every firmware i found here and online. It get´s recognized by usb burning tool but fails at 2%.....
                    Ok, boa tarde, alguém poderia me dizer como identificar o modelo específico do meu M8S?
                    You may only view thumbnails in this gallery. This gallery has 5 photos.
                      I have M8S with XT-s812-v10 PCB (pufangda_S812). The board is as in the pictures attached and you can find firmware here http://freaktab.com/forum/tv-player-...help-pls/page2 in post #25
                      You may only view thumbnails in this gallery. This gallery has 4 photos.
                        Hi
                        I am trying to get this box from android 4 to 5
                        having a heck of a time finding proper firmware.
                        the brand is evolvtv...but it' almost identical to digixstream. The board is dx4 plus v1.0
                        amologic s812 CHIPSET
                        my internal pics of box exceed the 2mb limit lol
                        so I will post after work.
                        Any help would be appreciated
                          Please help me to find firmwares to this TVBox !!!! Tried so many firmwares already with usb burning tool or boot card maker but it appears they are not combatible with this board.
                          the specs of this are
                          Amlogic S812, Quad Core, ARM Cortex A9, ARM Mali-450
                          16GB internal memory,
                          and 2GB RAM
                          • trebor
                            trebor commented
                            Editing a comment
                            One post is enough
                            No need to post same in new topic or threads if people know they will answer....
                            Thank You
                          #58
                          Thanks trebor
                          and yes you are totally right
                          sorry for any inconvenience
                            and 2GB RAM
                            Try this.
                            Use sdcard method.
                            if not mistaken the the usb burning won't work for this pcb.
                            I dont own one but i manage to help saved one before.
                              Try this.
                              Use sdcard method.
                              unfortunately mate its not compatible
