Un Known PCB FOR 812
    I've done a lot of research and believe this is a s812 device. Here is a link to the detailed specs --> http://specdevice.com/showspec.php?i...a-7e760033c587
    This second link is to the forum that I am using to attempt to get this INL3D Ultra4 device up to a min of Android 5.0
    https://forum.xda-developers.com/and...pment-t3410181
    If it helps, the TWRP build for mii (see near top of above link) works great on this box.
    EDIT:
    Found another source for a 5.1.1 build. It sounds promising as it specifically mentions n200c:
    http://www.ismallrt.com/android-loll...-box-download/
    Right now I am thinking about trying the stock based 5.0 ROM from xda-developers & then upgrade to the customer one. But the forum says to make sure that your device is s812 first. Any thoughts?
    EDIT:
    Well Father's Day is nearly here so I have left this too long. Will do my best attempt at this tonight. If anyone has any advice as to the best 5.x ROM & how to get there, then I would greatly appreciate it. There seem to be a ton of variations of this box out there so I am worried about messing things up with the wrong ROM. But at least I mangaed to get a full TWRP backup so I should be able to recover under most circumstances.
    EDIT:
    Found this forum post which got us up and running on Android 5.1.1.
    Hi all, I recently got hold of one of these OTT M8S boxes and have been banging my head against a wall ever since then. My ultimate objective is to load Openelec onto this and be done. The Android Firmware it comes with is flaky - especially on...
    You may only view thumbnails in this gallery. This gallery has 6 photos.
      Hi everybody!
      I have an andoid tv box, called OTT M8S 2G/8G 4K Android 4.4.
      I update it and brick it. [Facepalm] Anybody has the stock firmware to restore it? I load some IMG but the wifi donĀ“t work at all.
      attach some pictures of the box, it maybe help you to detect the right firmware.
      Thanks in advance
        Hello Everyone,
        Got a TV box lying around unused after subscription expired. It it possible to flash a firmware, with devices of closer spec?
        Amlogic S812-NV processor,
        Samsung DDR3-1600 2GB RAM,
        Toshiba 16GB eMMC,
        Realtek RTL8192DU WiFi-chipset.
        Wireless Chip
