MiniMX S905 - Ubuntu 16.04 64bits (with kodi and X) on sdcard
I found the solution here:
But it doesnt work on my side.
I got this kernel:
Linux odroid64 3.14.29 #25 SMP PREEMPT Fri Apr 22 16:24:15 EDT 2016 aarch64 aarch64 aarch64 GNU/Linux
Can you tell me if it's working on your side?
Edit:
We need this kernel from this Odroid-C2 release here, otherwise it wont work:
Need Koxx ! You're still alive?Last edited by int0x13; 11-23-2016, 18:19.
Originally posted by int0x13 View PostHi, when i upgrade my package with apt-get upgrade i get this result, do you know how to solve?
https://bpaste.net/show/fd07fe4ae4c7
I don't know why, but it breaks everything... including kodi.
I tried to migrate to latest kernel (79), same thing.
Did anybody manage to get a working ubuntu with latest kodi and kernel 79 working ?
edit : I tried balbes distro (debian, ubuntu & telos) and I didn't manage to get kodi working (core dump may be on egl, no interesting logs)
Here is what I get (another distro, but same issue)
After apt-get upgrade and kernel 79, kodi is dead.
The user permissions looks good :
odroid@odroid-jessie64:~$ groups
odroid adm tty cdrom sudo audio video input netdev
[/code]
But here it comes in dmesg:
Code:[ 98.185120] kodi.bin[1222]: unhandled level 1 translation fault (11) at 0xfffffffffffff8, esr 0x92000005 [ 98.185131] pgd = ffffffc0619e2000 [ 98.185136] [fffffffffffff8] *pgd=000000006076d003, *pmd=0000000000000000 [ 98.185149] CPU: 0 PID: 1222 Comm: kodi.bin Not tainted 3.14.79+ #1 [ 98.185153] task: ffffffc05d270c80 ti: ffffffc05d358000 task.ti: ffffffc05d358000 [ 98.185163] PC is at 0x115001c [ 98.185167] LR is at 0x114ffd4 [ 98.185171] pc : [<000000000115001c>] lr : [<000000000114ffd4>] pstate: a0000000 [ 98.185174] sp : 0000007fd2fd5060 [ 98.185178] x29: 0000007fd2fd5060 x28: 000000000229c0c0 [ 98.185183] x27: 000000000229c060 x26: 0000000002215000 [ 98.185188] x25: 000000000229c088 x24: 0000000000000000 [ 98.185193] x23: 0000000002a56628 x22: 0000000002a565e0 [ 98.185198] x21: 0000000002210000 x20: 0000000002b513d8 [ 98.185203] x19: 0000000002b513c8 x18: 0000007fd2fd4ea0 [ 98.185208] x17: 0000007fa4e53de8 x16: 000000000221d9d0 [ 98.185212] x15: 0000007fa379b588 x14: 00000000029a13b8 [ 98.185217] x13: ff00000000000000 x12: 0000000000000000 [ 98.185222] x11: 0000000000000038 x10: 0000000000000000 [ 98.185227] x9 : 1999999999999999 x8 : 0000000000000000 [ 98.185232] x7 : ffffffffffffffff x6 : 00000000000000ff [ 98.185237] x5 : 0000000000000000 x4 : 0000007fa38d9150 [ 98.185242] x3 : ffffffffffffffe8 x2 : fffffffffffffff8 [ 98.185247] x1 : 00000000ffffffff x0 : 0000000000000003
Code:22:16:31 T:547924938752 NOTICE: special://profile/ is mapped to: special://masterprofile/ 22:16:31 T:547924938752 NOTICE: ----------------------------------------------------------------------- 22:16:31 T:547924938752 NOTICE: Starting Kodi (16.1 Git:cdb7704). Platform: Linux ARM 64-bit 22:16:31 T:547924938752 NOTICE: Using Release Kodi x64 build 22:16:31 T:547924938752 NOTICE: Kodi compiled Aug 11 2016 by GCC 4.9.2 for Linux ARM 64-bit version 3.16.36 (200740) 22:16:31 T:547924938752 NOTICE: Running on Debian GNU/Linux 8 (jessie), kernel: Linux unknown CPU family 64-bit version 3.14.79 22:16:31 T:547924938752 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0 22:16:31 T:547924938752 NOTICE: 4 CPU cores available 22:16:31 T:547924938752 NOTICE: special://xbmc/ is mapped to: /usr/local/share/kodi 22:16:31 T:547924938752 NOTICE: special://xbmcbin/ is mapped to: /usr/local/lib/kodi 22:16:31 T:547924938752 NOTICE: special://masterprofile/ is mapped to: /home/kodi/.kodi/userdata 22:16:31 T:547924938752 NOTICE: special://home/ is mapped to: /home/kodi/.kodi 22:16:31 T:547924938752 NOTICE: special://temp/ is mapped to: /home/kodi/.kodi/temp 22:16:31 T:547924938752 NOTICE: The executable running is: /usr/local/lib/kodi/kodi.bin 22:16:31 T:547924938752 NOTICE: Local hostname: odroid-jessie64 22:16:31 T:547924938752 NOTICE: Log File is located: /home/kodi/.kodi/temp/kodi.log 22:16:31 T:547924938752 NOTICE: ----------------------------------------------------------------------- 22:16:31 T:547924938752 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files 22:16:31 T:547924938752 NOTICE: load settings... 22:16:31 T:547924938752 NOTICE: AML device detected 22:16:31 T:547924938752 NOTICE: Found 1 Lists of Devices 22:16:31 T:547924938752 NOTICE: Enumerated PULSE devices: 22:16:31 T:547924938752 NOTICE: Device 1 22:16:31 T:547924938752 NOTICE: m_deviceName : Default 22:16:31 T:547924938752 NOTICE: m_displayName : Default 22:16:31 T:547924938752 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO) 22:16:31 T:547924938752 NOTICE: m_deviceType : AE_DEVTYPE_PCM 22:16:31 T:547924938752 NOTICE: m_channels : FL,FR 22:16:31 T:547924938752 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 22:16:31 T:547924938752 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 22:16:31 T:547924938752 NOTICE: Device 2 22:16:31 T:547924938752 NOTICE: m_deviceName : alsa_output.platform-aml_m8_snd.analog-stereo 22:16:31 T:547924938752 NOTICE: m_displayName : AML-M8AUDIO Analog Stereo 22:16:31 T:547924938752 NOTICE: m_displayNameExtra: Analog Output (PULSEAUDIO) 22:16:31 T:547924938752 NOTICE: m_deviceType : AE_DEVTYPE_PCM 22:16:31 T:547924938752 NOTICE: m_channels : FL,FR 22:16:31 T:547924938752 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 22:16:31 T:547924938752 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 22:16:31 T:547924938752 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml) 22:16:31 T:547924938752 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 22:16:31 T:547924938752 NOTICE: Default DVD Player: dvdplayer 22:16:31 T:547924938752 NOTICE: Default Video Player: dvdplayer 22:16:31 T:547924938752 NOTICE: Default Audio Player: paplayer 22:16:31 T:547924938752 NOTICE: Disabled debug logging due to GUI setting. Level 0. 22:16:31 T:547924938752 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 22:16:31 T:547924938752 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 22:16:31 T:547924938752 NOTICE: Loaded playercorefactory configuration 22:16:31 T:547924938752 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 22:16:31 T:547924938752 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 22:16:31 T:547924861184 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 471 ms 22:16:31 T:547924938752 NOTICE: Running database version Addons20 22:16:32 T:547924938752 NOTICE: ADDONS: Using repository repository.xbmc.org 22:16:32 T:547924938752 NOTICE: Setup SDL 22:16:32 T:547924938752 NOTICE: Checking resolution 16
I have the minimx_Ubuntu image working quite nicely on a MXQ 4K (S905 with 1GB RAM). I'm using the DTB from my box with this image. The problem I have is that the uploads from this box are terribly slow. Download speeds are pretty good.
Eth0 connects at 1 gig full duplex, download speed via iperf is about ~500Mbps and upload speed is ~ 100Mbps.
the actual file download is fast enough that I don't care for it to be any faster. But the uploads are really slow ( like in 20 KB per second) even though iPerf says around 100Mbps.
has anyone done any speed tests /iPerf tests on the S905 using this image ?
I've even increased the TCP buffer memory using steps for Ubuntu but that hasn't made any difference. Any advice on how to go about troubleshooting this ?
Originally posted by KAA View Post
You flash to beelink mini mx3 and it work?
and extract dtb.img and copy it on the flashed SD card.
There are currently 2273 users online. 3 members and 2270 guests.
