A easy way to get dtb file is unzip the SD OTA file. I had many problems before discover it. Now i am using the 107L firmware without problems.
MiniMX S905 - Ubuntu 16.04 64bits (with kodi and X) on sdcard
Originally posted by Koxx View PostUbuntu image for MiniMX is ready !
v0 :
The image is require at least a 16Gb sdcard (can be resized to 8Gb after with gparted).
It doesn't modify the internal MMC memory... so you won't loose android.
What is working or not :
– boot : ok
– shell : ok
– ubuntu mate : ok
– sound : ok (manual operation needed)
– wifi : ok
– bluetooth : ok
– ir remote : ok
– kodi with hardware acceleration : ok (no 4k)
– cec : unknow
To install :
1 - use win32image or dd to copy it on sdcard, and inserd sdcard in minimx
2 - unplug minimx power
3 - press reset button under the box and keep it pressed
4 - replug minix power, and wait until minimx first bear logo image disappear
5 - release the reset button
6 - wait for boot
Login : odroid
Password : odroid
To start with graphical desktop after reboot :
sudo systemctl enable lightdm
To start graphical destkop once :
sudo startx
To start with kodi after reboot (disable light before) :
sudo systemctl enable kodifb
To start kodi once:
kodi
To disable bluetooth (in case of trouble):
sudo systemctl disable bt-up
To redirect sound to HDMI :
/home/odroid/sound.sh
To install firefox :
sudo apt-get firefox:armhf
To change boot resolution :
odroid@odroid64:~$ nano s905_autoscript.txt
... edit the conent ...
odroid@odroid64:~$ mkimage -A arm -O linux -T script -C none -d s905_autoscript.txt /media/boot/s905_autoscript
Linux kernel sources are still on the sdcard in case you need to add any drivers.
To compile and install :
odroid@odroid64:~/linux$ LOCALVERSION= make -j4
odroid@odroid64:~/linux$ sudo make modules_install
odroid@odroid64:~/linux$ sudo cp -f arch/arm64/boot/Image /media/boot/
odroid@odroid64:~/linux$ sync
odroid@odroid64:~/linux$ sudo reboot
Thanks a lot to SkOrPn and balbes150 for the help.
I have a question. Would anyone ever noticed that the USB side door (SD next) Mini MX does not work in Utuntu?
I started testing the device running ubuntu and thought it was a hardware problem , but I run Android after and
noticed that the door works normal. Does anyone have any idea how to turn the side door on Ubuntu?
( I am using the V1 image with all the upgrades via apt-get)
Originally posted by joaopuga View PostI have a question. Would anyone ever noticed that the USB side door (SD next) Mini MX does not work in Utuntu?
try:
echo 1 > /sys/devices/platform/dwc2_a/buspower
works on minimxiii and odroid c2 image.
if not check dwc2_b or something similar.
from @smarteswarm :
try:
Thank you. What you said worked properly . Only the path in my distribution was different. I put in the root cron the following line: reboot echo "1" > /sys/devices/dwc2_a/buspower
Originally posted by Koxx View Postif you have issues with the boot on sdcard, you may need to flash the L105 android firmware (it will erase the whole box content).
http://www.futeko.com/newforum/index.php?topic=565.0
Dear Koxx,
I have a mini MX and started using one of your images. But now I'm testing an image of Balbes150 made for Tronsmart Telos device. The image to the Telos worked properly through exchange of DTB and also s905_autoscript file because your file has specific root information for your image version, as the excerpt below:
setenv bootargs "root = LABEL = ubuntu rootwait rw $ {} condev no_console_suspend hdmimode = $ {m} m_bpp = $ {} m_bpp vout = $ {} fsck.repair vout = yes net.ifnames = 0 = 0 consoleblank hdmitx = $ { cec} "
The Ubuntu V3 Balbes150 file presented problems in the video, so I had to use the Armbian V2 file, which has the following passage:
setenv bootargs "root = LABEL = rootfs rootwait rootflags = data = writeback rw $ {} condev no_console_suspend hdmimode = $ {m} m_bpp = $ {} m_bpp fsck.repair = yes net.ifnames = 0"
Not sure, but this Armbian file must be causing problems to play sounds in HDMI, it has some missing parameters.
Then I will ask you ... Can you create a file as that generated for your image version of Ubuntu, but with LABEL and some other necessary parameter changes to the generic (as seen in the Ubuntu V3 Balbes150 file)?
I tested several raw files GitHub contained in the link: (The OK only are made to Armbian but no audio on the HDMI)
GitHub is where people build software. More than 100 million people use GitHub to discover, fork, and contribute to over 420 million projects.
Originally posted by balbes150 View PostI propose to make the same label : - BOOT boot partition - ROOTFS for the root partition. LABEL is necessary to register the same in the fstab file and in bootargs.
Add in boot partition second file s905_autoscrip_720 with settings for 720p60hz. Would a simple renaming of the file s905_autoscrip_720 in s905_autoscript to have the ability to download the monitors that don't support 1080. If your TV does not support 1080 can not boot and build file with parameters 720p60hz.
Which technique to change these files ? The text change does not solve , because I did a test and got no success .
Does the change by a hex editor would generate a functional file?
I believe that a file s905_autoscript similar to the original of Ubuntu created by Koxx , but the parameter label changed to rootfs should be enough to run your ubuntu V3 without problems in Mini MX .
See my more detailed case on the topic # 98 , just above .
s905_autoscript - It is a binary file. It can't be edited. Something would have to change it. 1. Clone the git (optional, not required, can use your text files). 2. Сhange text file s905_autoscript.txt 3. The make of an executable script. In the directory Script has a set of different files. Can see them as samples. In the README.MD quick instructions. If something is not clear, ask.
Originally posted by joaopuga View Post(I am using the V1 image with all the upgrades via apt-get)
I mean to ask: is running Kodi a valid alternative in terms of performance compared to running it from OE? And are the OE addons working (tvheadend and pvr.htc are what I use for DVB-T)?
Originally posted by balbes150 View Posts905_autoscript - It is a binary file. It can't be edited. Something would have to change it. 1. Clone the git (optional, not required, can use your text files). 2. Сhange text file s905_autoscript.txt 3. The make of an executable script. In the directory Script has a set of different files. Can see them as samples. In the README.MD quick instructions. If something is not clear, ask.
https://github.com/150balbes/Amlogic_s905
Thank you very much! The procedure worked OK in the script generation . Unfortunately not solved the audio problem in HDMI V3 version of your image for Telos . What is the procedure to compile the HDMI audio Amlogic for other versions of Kernel ? In the image of the Koxx HDMI audio outputs normally. Taking the opportunity .. my mini MX is 2GB , with chipset WIFI / BT AP6330 . I managed to get the Bluetooth working through pulseaudio , but I am having slow and interrupted audio . Any procedure for Bluetooth A2DP that works well ?
Originally posted by Nofan Tasi View PostWhen running v1 with up to date apt-get, does this ubuntu run with accelerated graphics (perhaps X11, wayland or DirectFB or...?).
Hello! So far I could not put the KODI to run . It is always giving segmentation error. I do not know the reason yet.
Currently it is also not in my priorities because I am using the Mini MX as a desktop low consumption. My videos I run a Raspberry PI 2 on the TV , which plays very well its function. Now Rasp run videos in 3D ISO . I think the Mini MX has a lot to improve to reach Rasp this point .
My priority now is to put the bluetooth to work ... You've used A2DP in yours?
About graphics acceleration , my Mini MX with fully updated Koxx V1 image is well with windows without leaving ghosts .. Videos on Youtube run OK in Firefox and Chromium , which does not happen with Ubuntu V3 Balbes .
Hi guys, sorry I'm not often here.
Thanks balbes for the help you provide to all users
I'll receive a MiniMXIII in 2 weeks.
I'll try to build a version compatible with the V1 and the III (with all drivers included), and I'll restart it from the Telos Ubuntu V3. Unless balbes goes faster than me to do it
I'll have a look on the balbes new scripts. (@balbes150, what are they doing exactly ?)
For X11, don't hope too much. The current Odroid C2 acceleration is only for openGL. It isn't miraculous.
There are currently 980 users online. 4 members and 976 guests.
