The 105L firmware release is an official release (not a custom). You may have to go backward because it seems 106L/107L may block sdcard booting. So yes, it may require backward flashing.
MiniMX S905 - Ubuntu 16.04 64bits (with kodi and X) on sdcard
Originally posted by Nofan Tasi View Postin my case it gives 40 Mbits/sec
(Me personally? It's not going to affect me. When running full Linux, I'll be hardwired... gigabit... into my E4200. When I put the thing in the livingroom (OpenELEC) it will be hardwired to my WUMC710, which I already know can do above 200 Mbps.)
but it seems I connect to 2.4G 802.11b/g/n
It could be specific to my Access Point (which is dual 2.4G 802.11b/g/n + 5G 802.11a/n)
I'll be trying that myself when mine arrives (and of course, I'll post results).
So, I guess that if/when my box arrives, if it has 105L on it, I should work to AVOID allowing any OTA upgrade, yes?
Originally posted by Koxx View PostUbuntu image for MiniMX is ready !
v0 :
The image is require at least a 16Gb sdcard (can be resized to 8Gb after with gparted).
It doesn't modify the internal MMC memory... so you won't loose android.
What is working or not :
boot : ok
shell : ok
ubuntu mate : ok
sound : ok (manual operation needed)
wifi : ok
bluetooth : ok
ir remote : ok
kodi with hardware acceleration : ok (no 4k)
cec : unknow
To install :
1 - use win32image or dd to copy it on sdcard, and inserd sdcard in minimx
2 - unplug minimx power
3 - press reset button under the box and keep it pressed
4 - replug minix power, and wait until minimx first bear logo image disappear
5 - release the reset button
6 - wait for boot
Login : odroid
Password : odroid
To start with graphical desktop after reboot :
sudo systemctl enable lightdm
To start graphical destkop once :
sudo startx
To start with kodi after reboot (disable light before) :
sudo systemctl enable kodifb
To start kodi once:
kodi
To disable bluetooth (in case of trouble):
sudo systemctl disable bt-up
To redirect sound to HDMI :
/home/odroid/sound.sh
To install firefox :
sudo apt-get firefox:armhf
To change boot resolution :
odroid@odroid64:~$ nano s905_autoscript.txt
... edit the conent ...
odroid@odroid64:~$ mkimage -A arm -O linux -T script -C none -d s905_autoscript.txt /media/boot/s905_autoscript
Linux kernel sources are still on the sdcard in case you need to add any drivers.
To compile and install :
odroid@odroid64:~/linux$ LOCALVERSION= make -j4
odroid@odroid64:~/linux$ sudo make modules_install
odroid@odroid64:~/linux$ sudo cp -f arch/arm64/boot/Image /media/boot/
odroid@odroid64:~/linux$ sync
odroid@odroid64:~/linux$ sudo reboot
Thanks a lot to SkOrPn and balbes150 for the help.
There are currently 2300 users online. 2 members and 2298 guests.
