NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
Originally posted by greekislandlover View PostMine is a p201 version of the MXQ PRO box too. is there any way to modify the p200 rom to work on the p201 box, or are there any other known working roms out there? Thanks
this ROM have different device drivers. this is why I have reported that the wireless , Ethernet and remote control is not working>
Originally posted by neomode View PostThis Rom is not for Flashing via Recovery.
You must Install the Rom via USB Burning Tool!
Neomode
Originally posted by neomode View PostFirstly forget that Error.
Second Flash again and Select Force erase all.
When you begin to Flash Plugin in the Power Supply.
Neomode
tried as you said and received "UBOOT/low power/send command/USB Control setup error"
edit: figured it out and feel dumb for not seeing this before wasnt using latest burning tool worked first try with latest tool.
Great ROM! Working great on my MXQ Pro p200 with an USB to Ethernet. Standby mode work flawlessly!!!
Do you recommend any bluetooth dongle (preferly 4.0+) that works on this kernel?
Is there anyway to control volume of a USB DAC or it doesn't support at all?
Thanks for making a great rom! Looking for more updates in the future
Originally posted by CapitalX View Postactually, the p200 and p201 are almost the same I tried both of them on my MXQ PRO p201.
I just got an MXQ-Plus yesterday. It uses Amlogic S905 64 bit SoC quad-core with quad-core Mali-450 GPU. Is the Plus version the same as the Pro version or close enough? I only want custom ROM because I hate the factory launcher and the lack of being able to restore the bottom bar with an up-swipe.
Originally posted by fwupow View PostI just got an MXQ-Plus yesterday. It uses Amlogic S905 64 bit SoC quad-core with quad-core Mali-450 GPU. Is the Plus version the same as the Pro version or close enough? I only want custom ROM because I hate the factory launcher and the lack of being able to restore the bottom bar with an up-swipe.
There are currently 4413 users online. 2 members and 4411 guests.
