NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
Would honestly love to see future updates to this
having this problem to sadlyLast edited by cgibbons51; 13 May 2016, 08:02.
Neomode, this is a great ROM. For the other 15 people in the world who own the MK808B Pro, let me assure you all that this ROM works great...with one exception, which I'm hoping you can help me out with. I absolutely hate the default launcher, and I don't know how you did it, but your ROM makes it impossible to change it. You can't change launchers in Settings, and you can't disable the default launcher (aptly titled "Launcher") in Apps.
For my purposes, the ROM is borderline unusable without being able to switch launchers. I'm willing to jump into a terminal and erase the damn thing, but I can't for the life of me figure out where it's located.
@neomode
Ah my nexbox MXQ pro doesn't have bluetooth built-in so that why I try to use a usb dongle.
I've an Avermedia A835/ rtl2832u but it doesn't seem like there is any app on the playstore that would support them so I'm getting this one http://www.****.com.au/itm/like/2014...&ul_noapp=true I'm not sure which chipset it's using but I'll try to find it out. Otherwise it would be great if you could list all supported usb dvb so I could buy it
Anyways thanks for making this rom, it's so much better than my stock rom, it fixes problem with exo player
Jerry
Originally posted by DeuSs View PostHi guys, sorry for this question, is this Rom for this device?
Because I want to buy a tv box and this one looks great and very low price... Ty
This one also works with this rom and has bluetooth built in:
proublot cgibbons51
The Problem here is that you Ethernet Adapter takes to much Power from USB.
S905 CPU needs more Power then a RK3188-T.
The Device comes with a 2A Power Supply that is just enough for the Device.
Neomode
Great ROM, thanks Ray. but would you please fix the Cam? in the stock rom when I plug a cam it just worked no problem. but in your rom it does not. There is no native cam app and when I installed a camera app from play store it shows a green color only :/ would please fix it to work smoothly. Maybe copy UVC drivers or something. Thanks a lot in advance.
There are currently 4378 users online. 2 members and 4376 guests.
