thanks
NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
Originally posted by blackbird920 View Postnice custom rom, if the wifi of mxq pro works in new version i'll donate too.
thanks
Originally posted by neomode View PostHello @BLeaCHeR
I am on Holiday this Week.
Next Week then i will finish it and release final.
There where a Lot of Changes so far.
Regards
Neomode
First of all! Have a nice holidays! Enjoy!!
Second, NICE!!!
Just one litle question, (maybe silly) is the u-boot in your images modiifed, to allow booting from SD or USB? I says this, because I'm trying to dual boot the box in the last days without success...
Regards,We’re the middle children of history, man. No purpose or place. We have no Great War. No Great Depression. Our Great War’s a spiritual war…
Originally posted by KyleRiemen View Post
If you want Wifi to work just put this file https://www.dropbox.com/s/jd8xuuoqka...8723bs.ko?dl=0 into /system/lib/ , replace the original one, set permissions to 644 and reboot. It is actually only the 8189es.ko renamed to 8723bs.ko.
it worksthanks a lot
Thanks KyleRiemen for this fix, it will work !
Another question: i can cast from my YouTube app to the mxq without a Problem, but how can i cast from any other APP ? Ive tryed some apps like allcast and localcast but i can find the device... What should i do ?
Originally posted by bhunt131 View PostDoes this fix the Ethernet as well or is there a way to fix that in a similar fashion?
Code:netcfg eth0 up dhcpcd eth0
Code:netcfg
Code:ifconfig eth0 192.168.X.X up route add default gw 192.168.Y.Y dev eth0 ndc resolver flushnet eth0 ndc resolver setnetdns eth0 8.8.8.8 8.8.4.4
There are currently 4605 users online. 2 members and 4603 guests.
