NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
Originally posted by KyleRiemen View Post
If you want Wifi to work just put this file https://www.dropbox.com/s/jd8xuuoqka...8723bs.ko?dl=0 into /system/lib/ , replace the original one, set permissions to 644 and reboot. It is actually only the 8189es.ko renamed to 8723bs.ko.
Tried # mount -o rw, remount /system
and # chmod 644 /system/lib/8723bs.ko
but no joy. Im a little rusty in my terminal skills. can you help?
Ive tried so many different things its too much to list. can't adb shell, or mount or chmod, su - adb remount, nothing allows me access.
How did you guys do it?
Thank you for the nice rom.
FOR 8188EU USER
My box is:
MXQ-S905-D16 = MXQ PRO 4K
V 1.0
DATE 151021
RT8188ETV chip on motherboard
Whith NEOMODE rom wifi not working? NO PROBLEM
download attachement and uncompress,
in /system/lib delete the 8723bs.ko
8188eu.ko and put on it on /system/lib
and after rename in 8723bs.ko, chmod to 644, reboot.
good rom solution for the community.
Thank you in advance.Attached FilesLast edited by dylan54; 10-20-2016, 09:57.
Originally posted by dylan54 View PostThank you for the nice rom.
FOR 8188EU USER
My box is:
V 1.0
DATE 151021
There are currently 2475 users online. 7 members and 2468 guests.
