NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
i did as stated still only see wifi one time then after reboot poof i think im missing some thing can some one compike these files into a ready made rom if so i think you would be king of the mxqpro world im trying but im such a noo beee at this lol
Originally posted by grzybu View PostHi,
I guess I've just bricked my box. I've tried to upload the image but it stuck on 2%.
Is my box dead or there is a way to fix this?
Here is the error log from USB Burining Tool:
Code:[13:21:08 568][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&607b864&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000005d8 [13:21:08 618][HUB1-1][Inf]-------------Download DDR.USB----------- [13:21:08 618][HUB1-1][Inf]--2-2-0-0 [13:21:08 618][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1 [13:21:09 119][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x00005183 [13:21:09 619][HUB1-1][Inf]--Write initial succeed [13:21:09 619][HUB1-1][Inf]--Upload encrypt at 0xc8100228 [13:21:09 619][HUB1-1][Inf]--ulValue = 0xadfc318c [13:21:09 619][HUB1-1][Inf]--Read encrypt value succeed [13:21:09 626][HUB1-1][Inf]--Transfer complete [13:21:09 627][HUB1-1][Inf]--Run at address 0xd9000000 [13:21:09 627][HUB1-1][Inf]--RunInRam succeed [13:21:09 628][HUB1-1][Inf]--2-2-0-0 [13:21:09 628][HUB1-1][Inf]--CheckFileRunState succeed [13:21:09 629][HUB1-1][Inf]--runResult:0x 0,paraMagic:0x3412cdab [13:21:09 629][HUB1-1][Err]--ReadPara failed [13:21:09 634][HUB1-1][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error [13:21:09 634][HUB1-1][Inf]--Close device handle 0x000005d8
Hi
Have the same problem let me know if you have solved it please.
Maybe a noob question, but I'm also having the Wifi problem (My remote also doesn't work btw!).
But how do I replace that certain file? The folder is read-only and there doesn't seem to be an option to enable root.
Do I still need to root my device? Or is there an option to enable root? Is there a certain file-browser I have to use? (One that is installed, since the playstore is not available without Wifi.)
Thanks in advance!
Originally posted by neomode View PostThe ROM is rooted without super SU app.
use x file explorer to replace it after you change his settings to use root and r/w.
Then you can do what you want.
Neomode
but the rest of it sucks the apps take for ever to open and then they just close out but the wifi is exactly how would i take the wifi driver from this folder and add it to a good working rom
that works great aside from having no wif
or is there a way you can clean this rom up and make it fast
if you charge for your work let me know i bought 4 boxes for my family for chirstmas the seller is no where to be found
and i have no money to get replacement gifts i just had half of my foot cut off due to diabeties i didnt even know i had it so money is tite and all i have is time
do you have any pointer can you offer any advise in noo bee terms
thank you in advance
Someone had problem with Dolby 5.1 ac3 audio?
When I play a film with kodi which have ac3 5.1 audio it "glitch" every 10-20 seconds.
If I play the same film with a player on smart tv it works fine.
I changed a lot of settings in kodi but always the same problem.
Can be a missing codec on Android tv box?
Thanks and happy New year to everybody
Inviato dal mio Z00D utilizzando Tapatalk
neomode
work this device with your new Version (Wlan + Ethernet)?
Thank you for your reply.
King regards
Originally posted by mike1111m View Postgot it to boot no wifi or ethernet?
A few posts back, I think I saw a workaround related to replacing the .ko module of the wifi to make this ROM work.
Also, I found a modified version of this ROM here:
This one already has the correct driver, and it works!
Regards,We’re the middle children of history, man. No purpose or place. We have no Great War. No Great Depression. Our Great War’s a spiritual war…
There are currently 4088 users online. 2 members and 4086 guests.
