NEOMODE CUSTOM ROM MK808B PRO S905 & MXQ PRO S905
Originally posted by KyleRiemen View Post
What problem?
I was talking about the s905 boxes lacking a lot of usb gamepad drivers. I originally bought this box for some retrogaming on the go but since it did't recognise most of the gamepads i own it was a real P.I.T.A
so if this custom rom has the drivers added to the kernel that would be a big deal for me. Thnx for everything guys
I guess I've just bricked my box. I've tried to upload the image but it stuck on 2%.
Is my box dead or there is a way to fix this?
Here is the error log from USB Burining Tool:
Code:[13:21:08 568][HUB1-1][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#5&607b864&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000005d8 [13:21:08 618][HUB1-1][Inf]-------------Download DDR.USB----------- [13:21:08 618][HUB1-1][Inf]--2-2-0-0 [13:21:08 618][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1 [13:21:09 119][HUB1-1][Inf]--Control write pll reg1 0xd9000000:0x00005183 [13:21:09 619][HUB1-1][Inf]--Write initial succeed [13:21:09 619][HUB1-1][Inf]--Upload encrypt at 0xc8100228 [13:21:09 619][HUB1-1][Inf]--ulValue = 0xadfc318c [13:21:09 619][HUB1-1][Inf]--Read encrypt value succeed [13:21:09 626][HUB1-1][Inf]--Transfer complete [13:21:09 627][HUB1-1][Inf]--Run at address 0xd9000000 [13:21:09 627][HUB1-1][Inf]--RunInRam succeed [13:21:09 628][HUB1-1][Inf]--2-2-0-0 [13:21:09 628][HUB1-1][Inf]--CheckFileRunState succeed [13:21:09 629][HUB1-1][Inf]--runResult:0x 0,paraMagic:0x3412cdab [13:21:09 629][HUB1-1][Err]--ReadPara failed [13:21:09 634][HUB1-1][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error [13:21:09 634][HUB1-1][Inf]--Close device handle 0x000005d8
Neomode wifi issues with MXQ pro 4k.
Steps that has been taken so far:
1.) downloaded "8188eu.ko" file onto usb drive.
2.) using Root explorer changed my directories permission to read/write >
3.) Removed the "8723bs.ko" file.
4.) Placed the "8188eu.ko" file into the following directory- system/lib
6.) Changed "8723bs.ko" files permission to chmod to 644
7.) Rebooted my MXQ Pro 4k device.
My wifi networks are now populating but I am not able to connect to my network.
Error msg: "Password is not valid"
ALREADYVERIFIED THAT I AM USING MY CORRECT WIFI PASSWORD.
I was trying to connect to my 2.4 ghz wifi network when I received that error msg
My 5 ghz option isn't disabled and doesn't show up on the list even if I wanted to select it.
Is there a method to at-least connect via Ethernet until the wifi issue has been resolved?
Originally posted by salimus View PostI originally bought this box for some retrogaming on the go but since it did't recognise most of the gamepads i own it was a real P.I.T.A
Kernel Modules Files https://www.dropbox.com/s/r2pqhcgo7m...mepad.zip?dl=0
Originally posted by aj1982aj View PostDoe any body have a working firmware for the s905 mxq pro 4k with the blue board and realteck 8188 drivers installed?
This one should have it
Originally posted by tSwaggR View PostMy 5 ghz option isn't disabled and doesn't show up on the list even if I wanted to select it.
No, Ethernet will not work with this ROM. You will have to use another ROM.
http://freaktab.com/forum/developmen...k-in-progress/
https://mega.nz/#!191kBSAB!Rb7PpqShvQJcbHu0r0wa0IQNcWsam3dBn0s8Cv5d YHE
MXQ Pro does not support 5ghz network.
but every thing else about the rom is horribly slow any ideas on how to take the wifi from that rom and add it to one that works
like this one i hear this one has great usb game pad support
i think if some one added the wifi drivers to that rom it would be a kick ass rom
There are currently 2515 users online. 1 members and 2514 guests.
