OTT MXQ 4K Pro - New build testing
Hi guys i just flashed my first rom on my mxq pro p201t with usb burning tool, it worked all wel hugsun_s905_mxq_rtl8189_20160225
but its pre rooted
i need one without root ore a way to instal xposed to hide the root
any help ?
thanks already its my first post i read alot an try but now im stuck,
I wish there were some easy matrix telling which exact firmware runs on which exact MXQ Pro :-)
I do not have a windows machine to unpack the images. Each time I flash an img I need to drive to a friend.
So could someone please provide the build prop of the 905_MXQpro_aml_upgrade_package-20160530 and hugsun_s905_mxq_20160527?
At least, their fingerprint?
I have same board as Goudtik (see 'Summary: Different s905 boards' thread) and my current fingerprint is:
Code:ro.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20160308:user/test-keys
update
I could actually spot some values inside the img
Code:hugsun_s905_mxq_20160527 ro.product.model=MXQ Pro ro.board.platform=gxbaby ro.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20160527:userdebug/test-keys
Code:905_MXQpro_aml_upgrade_package-20160530 ro.product.model=MXQPro ro.board.platform=gxbaby ro.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20160530:userdebug/test-keys
Code:(my)MXQPRO-20160315-V3MXQPRO-0315 ro.product.model=MXQPRO ro.board.platform=gxbaby o.build.fingerprint=Android/p201/p201:5.1.1/LMY47V/20160308:user/test-keys
Originally posted by Nofan TasiI wish there were some easy matrix telling which exact firmware runs on which exact MXQ Pro :-)
Enviado desde mi Lenovo K910 mediante Tapatalk
Tried that on my "OTT MXQ pro, 2GB/16GB/bluetooth/p201".
Notices
- not correct fw for my device; Lost bluetooth and memory limited to 1G
- wlan initially disabled, had to to turn it back on in android settings
- google play works
- ir-remote seemed to work (however, I dont use it but separate air mouse)
- deleting "/system/etc/allowbackgroundapp.list" improves multitasking between apps
- overall performance suffering, possibly due to misconfig of memory
- flashed via sdcard in recovery mode (duh, wasted money into usb A-A cable)
- reset switch in my box is not inside AV port, but in SDIF audio port instead
Originally posted by Macrom View PostFinally heat sink replaced..
Antutu jumps from 33k to 37k with this. Stress test passed to.
Instead i bought a smaller but taller one, made of copper and used thermal silicone instead of thermal paste since it dries out and hardens, securing it in place. And since the heatsink is only 1mm apart from the top metal plate, i also put a thermal pad between them so they could touch and exchange the heat.
My score varies from 27k to 37k but it seems to be related to antutu. If the 3d test fails i'll get a much lower score. It's probably related to low ram.. i have to keep trying until the 3d test runs and then it gives me the 37k score.
Hi! I would like to install http://chinagadgetsreviews.com/downl...n-mxq-pro.html
but since I am on Kerber fix v3, I can not get to Revocery anymore. Toothpick-Method does not work anymore. Is there any other method someone knows? Perhaps on SD or USB? thx
There are currently 2093 users online. 5 members and 2088 guests.
