Vec
OTT MXQ 4K Pro - New build testing
Originally posted by veclinux View Post
I have installed this firmware too seems to work ok,,,,,,,,,,,mind telling me how you rooted it.......I tried ezroot from this forum but did not work for me........thanks
VecDownload the link below.Unzip the file and put the 3 files on a SDcard.ezroot.ziprecovery.imgfactory_update_param.amlNow this is the important part. We need to boot the recovery you put on SDcard not the internal recovery or the ezroot.zip will fail signature.Go to "My Apps" and run "Update & Backup".Click on "Local Update" and click on "Select". It should find ezroot.zip on your SDcard.Select that and proceed.It will reboot and install the update and your done!Enjoy the perfect root
Link s905_ez_root.zip
https://www.dropbox.com/s/iizxb70ywc..._root.zip?dl=0
If this doesn´t work, then i don´t know what more can i tell you...
Works fine for me.
Originally posted by Macrom View Post
No way with 2.0.7 allways error at formatting step.
Can't rollback with it too.
Marcom.. I am getting similar errors with 2.0.7, what did you do to solve the problem ?
EDIT:
Ok not sure what I did, but my cable had some sort of bump (transformer?) on one end.. After swapping the ends of the cable (PC<=>mxq), it all started to work and it seems I now have successful burn with wifi working.Last edited by rapalax; 05-26-2016, 04:09.
Originally posted by rapalax View PostTested L-MXQPRO-KODI-0511 and seems pretty stable up until I got Kodi from the play store and enabled passthrough. The entire box will consistently hang if you try to play something with 5.1 AAC audio
Can someone suggest another ROM ? How about hugsun_s905_mxq_20160509 ?
Cheers,
Vec
I tried hugsun would not burn for me........my problem with the L-Mxpro is stuff like salts and exodus hang trying to resolve the sources not sure if its the 1 gig ram or the firmware all my other boxes are 2 gig boxes and they work ok going to try to get original firmware from my supplier will report back............
Cheers,
VecYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Well i decided to redo my cooling again in my box, so i bought a sheet of thermal pad, removed the top metal plate on the box, used another and bigger heatsink, bought a cheap notebook cooler with 2 fans (dismantled it), built a wooden box an placed the plastic structure with fans inside.
Now after some testing the temperatures are good!
When i´m doing light tasks temps go from 39º and 50º celsius.
When i´m doing heavy tasks ( ran stability test from antutu) temps hit the max temperature of 63º celsius which is pretty amazing and safe to say that heating won´t be an issue from now on.
A few days back i showed to you another cooling setup but heating was still severe, after some time connected and doing heavy tasking ( ran stability test from antutu) temperature rose to about 85º celsius just within 3 minutes of testing so i decided that it wasn´t an effective cooling solution because the heat was trapped inside and of course it will be catastrophic after some time as passed.
Fans and better coolers do all the difference!Last edited by hmsgr; 06-02-2016, 16:50.
There are currently 2420 users online. 3 members and 2417 guests.
