I tried hugsun would not burn for me........my problem with the L-Mxpro is stuff like salts and exodus hang trying to resolve the sources not sure if its the 1 gig ram or the firmware all my other boxes are 2 gig boxes and they work ok going to try to get original firmware from my supplier will report back............
Cheers,
Vec
So I have tried both : L-MXQPRO-KODI-0511 and hugsun_s905_mxq_20160509 ... Both of them seem to be equally bad when it comes to Kodi Stability (both hang on AAC 5.1 audio w/ Passthrough) and hugsun_s905_mxq_20160509 seems terrible for my 8189etv wifi reception.
I remember my stock ROM dated ~ 0314 was fine for Kodi.. would anyone have that version available ? Or maybe may something else to suggest ?
Hi can this firmware be installed if we copy to sd card? I know you can use usb burning tool, but it has u-boot.bin.sd.bin , just wondering if it can be installed from an sd card?
Nice Work ;-) Two Thinks 1. The power Adapter is to small dimensioned for the Amlogic s905, with 2Amper -> Dont supply the Fans from the USB 2.Turn the Fans around and suck the warm air out the case. Maybe interesting --> Neomode is perhaps working on a ROM for the MXQ Pro 4K http://freaktab.com/forum/tv-player-...5-mxq-pro-s905 -Page 7 --> Use Trickster Mod -APP and push the CPU Frequency and performance settings for fluent working. So on you can see that all 4 cores are Wirkung --> Xposed Framework works (32Bit) but not with all Function e.g. Awesome Pop-Up or XhaloFloatingWindow (no portable Windows/multi Windows) --> If you want usw a bigger power Adapter , See current carrying capacity of conductor tracks Habe a nice Day
You may only view thumbnails in this gallery.
This gallery has 1 photos.
Two Thinks
