The first ROM was based on Morka's sudo 1.12. Morka has released some updated APKs which he now calls 1.13 specific for the 10G2. I have tested these but really see no difference?
So this new updated ROM is exactly the same as before but with these updated APKs
Camera, Settings, SystemUI, Gallery3d, LatinIME
For those that have already flashed yesterday ROM (link now gone) you "may" get by with only having to FLASH system.img with the tool. But to be safe a full eraseIDB and reflash is reccomended. If you get force close on stuff flashing only system.img, then try a full reflash.
The link down below has been updated so use it to download the new ROM. The file name now has 1.13 in it.
Enjoy,
_____________________________________
This ROM is by popular request! Morka's Honeycomb like ROM which I like to call HoneyBread
This is Morka's ROM with some apps removed and my changes for PROPER EXT4 for speed, and other modification for performance that I have been doing with all my ROMs.
PLEASE READ....... THE README.TXT file in my ROM kit to understand the details and changes I have made. It is really too much to document here in this post but here is a summary:
1) I had to removed all Morka's added apps due to no factual understanding of copyright. It is super important that we all understand copyright and even if apps are FREE it does not mean you have the right to distribute. I really do understand this stuff so for this Web site and protection from law suites, I had to remove this stuff. If Morka got the OK from a copyright owner to distribute in his ROM, great.... But I do not know about this and thus I must be careful. Last thing we want is a shutdown because of a simple violation of the EULA. I hope you all understand this?
2) I removed most of Morka's changes to build.prop. I have done a hell of a lot of testing and I know these build.prop changes and I found most of them give stability issues vs the trade off to performance! A lot of these mods are well known but when and where to apply them is a user preference. So again READ the readme.txt as I list what I removed so you can easily add them if you want. I think you will find my updated ROM performance far exceeds anything add in build.prop! But you all be the judge! I expect you too
WARNING! This is for the Arnova 10 G2 ONLY. It is NOT for the 10b G2 resistive or capacitive versions! Flash this and you WILL brick your tablet if you do not have a 10 G2!
NOTE: Morka's ROM had Button Savior on because some apps go full screen and you CANNOT exit back to the Launcher! I had to remove it from the ROM since we really do not have permission from the developer to include it in a ROM.
So if you go to the Market (Google Play) and download and install Button Savior, this exit problem will be fixed.
https://play.google.com/store/apps/d...FydC5zd2tleSJd
Finally, this is NOT my ROM. It is Morka's ROM with my root and performance enhancements as requested by users here!! If there is a BUG in the ROM, I cannot help you and this is not a problem with my version. It is a BUG in the Morka ROM. He is constantly working on improving his ROM and so I will try to do the same as he releases more versions.
Please remember to give Morka
.gif)
This ROM is based off of Morka's 1.0 ROM with updated library files and launcher3.0. It is what he would call Morka Mod 1.12.
As of this date Mar 12 2012, this is Morka's latest ROM for the 10 G2.
Last note: I have invited Morka to join the ROM developers group here. He has an open invite with no strings attached
MORKA, Please if you would like, we would be happy to have you and you can have a download area with no strings attached! No pop-up advertising downloads, etc! Please I hope you join us here
OK so here is the download for the Morka ROM with Finless Enhancements:
ROM DOWNLOAD -> Arnova 10G2 MORKA MOD 1.13 + Finless MODS (163 megs)
I hope you enjoy this ROM!
Damo - Forum Moderator
PLEASE CLICK THE DONATE LINK BELOW
PS
If you are having trouble with the above link when using Tapatalk than here is the email link for donations below
https://www.paypal.com/cgi-bin/websc...=ZYCM4NZ4J6F3G
Thank You
