Btw, trying to factory reset it in the Recovery gives the same error so the issue could be with the Recovery.
Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Well yes looks like it, Green man falls over dead here,
There was a previous update few days ago I had troubles but finally went in.
This one no happy at all,
Just wait, like all things it will happen.
Cheers
Looking at on screen error, expects a fingerprint Blah, Blah, 20160706 or Blah, Blah, 20160719, but this device has yadda yadda, 20160704,
well looks like to me that's a bit of an issue, HmmmLast edited by trebor; 07-21-2016, 22:18.
dastinger.. advancesettings wiki: http://kodi.wiki/view/advancedsettin...twork_settings Section 2.8.3 has the settings that I alluded to. Specifically, buffermode and readbufferfactor..Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by trebor View PostWell yes looks like it, Green man falls over dead here,
Cheers
Thanks a lot!
Originally posted by cjeman View Postdastinger.. advancesettings wiki: http://kodi.wiki/view/advancedsettin...twork_settings Section 2.8.3 has the settings that I alluded to. Specifically, buffermode and readbufferfactor..
I also was on update 06, Post here show the OTA used.
I guess attempting to put in this current 19 it did evil, and reset the system.
If someone has the 06 update still and can share, can try again or wait easy.
Cheers.
hello..what are the differences between this box and the larger sized M8S...or are all M8s' the mini? seeing that the wifi isn't much to talk about with the mini..possibly the larger m8s has better wifi performance? thanks allLast edited by kansasjayhawk32; 07-22-2016, 22:11.
dastinger.. kinkin has written a program that maintains advancedsettings.xml within Kodi. It appears that the Freaktab lords do not allow URL'S for tvaddons to be included in posts, so do a search on advancedsettings.xml+kinkin and you will find the plugin download there.Nvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by trebor View PostNew Firmware 20160719:
http://freaktab.com/forum/tv-player-...-10-100-lan-bt
Thanks a lot trebor!
Now, if only it fixed DD/DTS passthrough. It's driving me nuts but I think the issue might be with Kodi. Anyone's got a solution?
@cjeman
I tried editing the buffer type and size but it didn't help. Audio passthrough is still an issue. Everything's fine on MX Player.
There are currently 3071 users online. 4 members and 3067 guests.
