Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by dastinger View PostYes, first thing I tried but the issue persists. I can get passthrough to work but the sound ducks/glitches for half a second from time to time and it's impossible to watch a movie like that.
Originally posted by trebor View PostNew Firmware 20160719:
http://freaktab.com/forum/tv-player-...-10-100-lan-bt
Hi guys, hope you can help me, I got a Mini M8S II S905x tv box - everything worked fine for a couple of days. It then came up with the OTA update so I downloaded it and installed - my box is now bricked. After a bit of research the USB Burning Tool can see the box even though there is no power light on the front, so I contacted the seller and she sent me a link to the firmware for it - sd_update_minim8s_rv106L04 - this file loads into the USB Burning Tool but I get the following error when I try to update - [0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error. Ive tried a couple of times but still the same, I've even downloaded the firmware that I found in this thread but that file is for a SD card update. I don't know what to do and can't seem to find the IMG file to use with the USB Burning Tool - anybody have any ideas??
That's what I think too, so I found the update in this forum - sd_MINIM8SII_rv102.zip, but this is the files for the SD card upgrade which won't help me because I can't get this tv box to actually startup - no power LED or picture on the TV. It's as if this box is bricked, has anybody come across the IMG file for this box so I could try to update it using the USB Burning tool. Or does anybody know if I can short any pins on this board like I've seen on some other Amlogic boards to kick some life back into it? Of course I got this from China so sending it back just isn't worth it !!!
Yeah, tried the reset button, tried without the reset button. I've been reading a lot on this forum and others and have tried everything but to no avail. I have the older version of this box the Mini M8S with the S905 CPU and got Openelec installed with no issues and even went back to Android using the USB Burning tool so I know my OTG cable and everything is fine, I reckon this new box has had it, sometimes I suppose what do we expect for €50 ?? It sounds more like a hard brick than soft do you think? Thanks for your help by the way, I do appreciate your time !
There are currently 4200 users online. 0 members and 4200 guests.
