Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by array81 View PostIs there a working link for last official firmware? (I think r115)
1) https://www.entertainmentbox.com/min...-6-0-firmware/
2) https://mega.nz/#!9IYgBboR!j_laGJufS...baAqX8QVvvzBg4
The second one is the 112. If you install this successfully on your tv box then from android settings you'll be able to install the 115 update.
Where can i find a android tv rom that still works? i have one made by superceleron but it got a few years and somehow the google play services cannot update some part that is needed for some apps to work.
What can i do? i want the android tv version, not just android. Is there a newer rom?
Please help me. Thanks
Originally posted by jms74 View PostWhere can i find a android tv rom that still works? i have one made by superceleron but it got a few years and somehow the google play services cannot update some part that is needed for some apps to work.
Now above at top of page / should see
Firmware Roms Tools
Click on
Many Stickys
All are Roms to Test
Half way down will see Rom Superceleron
Happy Testing
Originally posted by freddy View Post
Back out of this thread
Firmware Roms Tools
Click on
Many Stickys
Happy Testing
Originally posted by soulfunkdjx View Post
Check these links
I don't know man. I installed it via AmLogic USB Burning Tool.
You can find it here: https://androidmtk.com/download-amlo...b-burning-tool
Can please anyone post links to some file with latest stock rom that I can flash from TWRP? Needs to be flashed from recovery as I don't have access to computer now.
And also if possible please also post a file with with a Android tv rom that is stable and good. Also needs to be a file for flashing in recovery. TWRP if that matters .
There are currently 3729 users online. 1 members and 3728 guests.
