Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by Terminou View PostWhat TV box do you suggest? I want to buy a new that works very well.
Originally posted by lallo89 View Post
can you show me the guide to shorting the pins? because I have restored 1 box via otg cable, but with another box, I can't because my pc not find it
Now I have r112 megabox but I am not satisfied due to some bugs. Every time I am in the middle of installing sth and go zapping tv stations on tv and then go again to android box it powers off. Also I can't install exodus it can't connect to fusion. I don't know why.
So what is the best choice now? To go to megabox r115 or to official Rom and which one?? And in what way should I install the new Rom? Now I am in r112megabox I repeat. Thanks.
Originally posted by geornirv View Post
Look at my post 842.
Originally posted by soulfunkdjx View Post
I think your android tv box is powers off because you have enabled the cec option. Go to settings and disable it. Otherwise i don't know what it is. Try another tv. The reason you can't install exodus and fusion is because these addons are abandonded by their developers and are not working anymore. You should try "Covenant" addon (is the same as exodus but with different name) and for fusion try the "SuperRepo" addon. So your box has no problems. You can try and installing the 115 version. Is better to have the latest versions anyway.
which 115 ?? Is there a stock andcustom or only custom ?? Can you paste a link?? Thanks
No I dont mean powers off after a while. I know about cec option. It powers off when I go out of the tv box channel and go in again. Then it disconnects.
The link is in post #868
and the procedure in post #872.
The link in post #874 didn't work for me.
I assume you have a 4K TV? If you have then it will be appear at the display settings.
The max resolution is 1080p in display settings.
In the beginning, I had 4K resolution, but not now on ATV ROM and after reinstalling original ROM.
What can I do ?
Command line on terminal ?
Thank you.
Originally posted by hsrn View Posti had ver 109 installed on my box.
updating through stock recovery didn't work.
so i have first installed twrp 3.1.1.0 ( https://1drv.ms/u/s!AoqocX31ecnXgZwNCL9pqWEsLDw_hg )
then i could install ver 115 through twrp without any problems.
i have used this file to update:
https://yadi.sk/d/ojqQlkM43JsXmy
There are currently 1675 users online. 2 members and 1673 guests.
