Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by nmou99 View PostHello all, I'm new here and I have a problem with my mini m8s II box
I have rv112 firmware installed on it and I use an Rii mx3-m remote with it and the problem is that when I want to scroll down or up a page on some apps (like chrome), the mouse select texts ... it doesnt scroll
If you understand me then help please thanx
Hi. I'm new here because of a problem.
I own the Mini M8s II which functioned perfectly until yesterday. I always left it on but yesterday it seemed stuck on the screensaver. I couldn't bring it back using my keyboard or remote, so i unplugged the power cord. That was the end of it, i can't turn it on, i used the usb cable connecting it to my pc, tried the USB burning tool but nothing. It gets to 7% and stops, saying Disk Initialize/Send command/error result.
Can i do anything or is it dead?
Guest
I'm trying to view USTVNOW through a web browser (Chrome, Built in Browser, Dolphin, UC Browser) but the device is unable to play the channels.
It works on my ancient minix X7 and windows PC but cannot get the streams cannot be viewed on the mini m8sii with Amlogic.
Has anyone experienced the same and is there something in the firmware preventing USTVnow streams playing, its rather annoying this device cannot play such a simple stream.
Originally posted by soulfunkdjx View PostHello guys. I have noticed that my Google Play Store won'tpdate anymore. i have the version 6.8.20 and the latest version out there is 7.9.34.
Tried updating to the latest version manually but it won't install.
Originally posted by array81 View PostThis is firmware r115. You can install it from SD, it's work but I don't have a changelog. Then boot animation is change. (source 4pda.ru)
Do you know if this update has the megabox boot animation? Or do you know if this has the brightness fix?
There are currently 2175 users online. 1 members and 2174 guests.
