Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Hi guys, sorry about the photos, I've uploaded proper ones here - https://1drv.ms/f/s!Aj02sMOi4_lyg5Ba_Ui_rgcpJ-uREQ
Thank you for all the help .
Originally posted by rahzel View PostThe 'fix' is to play a 4k video. This will change the RGB mode from 0-255 to 16-235. In layman's terms, it will look brighter.
There are custom roms in the firmware section that have this 'fix' built into the splash screen, so every time you boot-up the box, it will automatically set it brighter.
Originally posted by Alexxx79 View Post
Firmware rv_109 - 30.11.2016 from Vontar mini m8s+ CD card method
And the same version of official firmware for Vontar Mini m8s+ for upgrade method with SD card and recovery. Forks fine on mini m8s II 2/8gb.
Extract the files from the archive.
copy update.zip file to TF-card (make sure it is FAT32 format), then run Update&Backup app to update system by local.
Thanks #Vidim!
Updating from usb pendrive is the same than updating from TF-card?
Thanks in advance
FYI, it seems that we have new stock firmware versions for this box:
Version 112 for Mini M8S II TV Box: https://chinagadgetsreviews.com/down...-tv-box-3.html
Version 111 for Mini M8S II TV Box: http://chinagadgetsreviews.blogspot....mallow-60.html
Version 110 for Mini M8s II TV Box: http://chinagadgetsreviews.blogspot....mallow-60.html
Does anyone know if and where we could find the changelog for these new versions ?
Originally posted by rahzel View PostAll of the links show the 1GB version... does it matter?
Anyone try them out yet? Would be awesome if they fixed the brightness issue.
http://freaktab.com/forum/tv-player-...roid-tv/page14
I haven't tried these new firmwares (I currently use XannyTech's custom rom), but I could pretty much guess that the new firmwares are for both the 1/8 and the 2/16 versions for the box.
There is no reason the manufacturers of the box would release firmwares only for the 1/8 version.
Just to let you know that i also upgraded my Mini M8S II to rv112.
i did it from a microsd card using the burn card maker.
this crappy software didn't want to format the sd card, so i formatted it in windows to fat32 before writing.
After writing it takes 5 or 10 minutes to fully load the first time.
That was little bit scary ;-)
There are currently 2728 users online. 0 members and 2728 guests.
