Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by statho.christos View PostHello. I receive my box today fron gearbest. I have some problems. When i go to kodi and get out (exit) then it freeze , and also i put my google account . Playstore is ok. I download the chrome apk but it can't connect to my account. (Gmail). I tried to do update on the machine but it say that i have thr latest version. If i put the latest firmware here fix these problems? And which firmware to put on ? Thanks
Originally posted by Conspiracy View PostI successfully installed the 13.10.2016 version on my T95N. But now my remote is no longer working.
Solving the problem with the "black screen" (black shadows or low brightness)
Thank you "crazzian"
1. Download the archive https://yadi.sk/d/94s27z7L33Uxuf
Select any video file!
2. Rename the video file in the "bootvideo", the extension does not specify (empty file extension).
3. Copy to Folder
\ System \ etc \
We confirm the replacement (if necessary, who is there before you can rename the file).
3. Expose the permissions 644 (rw-r - r--), if they are different.
4. In the file
\ System \ build.prop
Modifies the parameter to 1
service.bootvideo = 1
5. Reboot.Last edited by vldim; 14 December 2016, 13:12.
Originally posted by Terminou View PostIs the purple screen issue solved?
just buy this: HDMI Male to VGA Female Converter Adapter
Audio cable in 3.5mm jack
Everything works perfectly! This is the only solution!
Firmware rv_109 - 30.11.2016 from Vontar mini m8s+
(for mini m8s II, COOLEME MB1, Tanix Tx5, X9 4K, Vontar mini m8s+)
for Amlogic USB Burning Tool
Set using "Amlogic USB Burning Tool" and cable USB A Male - A Male.
Run program "Amlogic USB Burning Tool" and press button "start".
Press the RESET button (hold) at the TV box, and plug the cable USB A Male - A Male.
Installation begins.
Changes:
1. fix key Enter in USB keyboard
2. fix out of the player Kodi (exit button now works well)
Firmware XTMOD - 06.12.2016
http://forum.xda-developers.com/andr...ustom-t3513805
Originally posted by vldim View PostFirmware rv_109 - 30.11.2016 from Vontar mini m8s+
Changes:
Is there new about a new OTA?
Originally posted by array81 View PostIs this the official firmware for our Mini M8S II?
Vontar mini m8s+ and Mini M8S II - It is the same. Firmware is the same.
I did not find our Mini M8S II
The manufacturer does not go with me to communicate. Silent.
Originally posted by vldim View PostYes, it's official firmware for Vontar mini m8s+
There are currently 2553 users online. 1 members and 2552 guests.
