Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by solitron View Post
Unfortunately my TV does not have VGA.
This unit is the best solution I've tested it on a Sony TV that has a pink, green problem.
Does anyone use iptv with f4m tester and Catoal Addon?
The channel is 1 second and stops.The image is always frozen. I set the buffer with "Easy Advanced Settings" but I have no good results. Also I deleted cache and configured f4mtester to 800. Some channels have quality 720 and have enough speed internet.
Maybe the server is slow or Tv Box is not doing well with IPTV?
Thanks.
Originally posted by tosu View PostDoes anyone use iptv with f4m tester and Catoal Addon?
Thanks.
Hi
Some one can help to in fix brightness script to final firmware https://yadi.sk/d/tGBtKTKJwsd8y
Box it's perfect but brightness it's too low
Originally posted by gale View Post
http://www.gearbest.com/cables-conne...pp_242059.html
Originally posted by sweetnonso View Post
Wrong forum, am afraid.
I have problems with permissions on folders. Kodi can not write to a folder on the sd. I can not use as a cache to sd torrent watching movies more than 2gb. Because I can only use the internal storage and is what I have free
It can also be a problem cache, permissions or something related to the firmware or configuration.
I'm not asking as see iptv.
Originally posted by array81 View PostI have this problem/bug. If turn-off my TV but not my TV BOX and then turn-on again my TV then TV BOX turns off automatically.
Originally posted by Alexxx79 View Post
I have oposite situation, with TV - LG 3D Cinema model. I solved that - first turn off my TV and than Box. When I turn on TV and select Input device TV Box, automaticly Box will turn on. I think that is not a bug,, TV send signal through HDMI to power on Box. But, regarding Your issue it seems that power button on remote control for TV has the same function and for TV box too 😀.
Hi there,
My friend just bought me this box. I hooked it up and Kodi and Youtube are working fine, however, I am not getting the quality on Youtube to display in 4k when watching some 4k content.
In the settings for the tv box, it is auto setting my display quality to 4k 60hz. I looked through all 38 pages, but I couldn't find an answer besides from other people asking about 4k Youtube.
Any ideas? Thanks.
There are currently 3775 users online. 0 members and 3775 guests.
