Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by Joffa View PostI read an early review stating this box wont write to usb stick or HDD. Has this issue been addressed in firmware updates? I want to be able to download torrents directly on this box.
Put the program tTorrent
Go to "Settings", then select "Program Folders"
Specifies the path and write permissions.
Originally posted by rahzel View Post@vldim, may I ask how you're getting these update files? Do you work for the manufacturer of this box?
I know the email manufacturer in China.
I write them letters. I inform them of bugs and problems. They send me the firmware.
The next firmware will fix the problem with the key ENTER at USB keyboard.Last edited by vldim; 18 October 2016, 11:51.
Originally posted by array81After upgrade by SD to last firmware (13/10/2016) I get a message error on device boot about application "Update&Backup"
Once I pressed the update button, the update app seems that its not responding, I click on "wait" 3-4 times. It did install correctly after all.
Originally posted by array81 View Post
See post #451
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by rahzel View PostThat's because amcodec causes the box to switch to RGB Limited Range universally (meaning outside of Kodi as well). Amcodec support was added in the most recent software update for the M8S Mini II (20160923). Previous versions didn't have an amcodec option available in Kodi.
This is a bug... the RGB range changes when using amcodec... that's not a good thing. Next time you boot your box up, it will switch back until you play a video in Kodi with amcodec checked.
I have contacted gearbest about this and they have forwarded it to the manufacturer.
So right now your options are to either use amcodec and leave your TV alone (just remember that when you reboot your box, it will reset to RGB Full again until you play a video in Kodi). Or you can disable amcodec in Kodi and set your TV to match the box by setting it to HDMI RGB Range Nonstandard.
(Looked in my TV for HDMI RGB Range option, does not exist).
There are currently 3787 users online. 1 members and 3786 guests.
