Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by Andrei80 View PostIs there a way to make Android TV remote work with this box? Or some other remote app that turns an Android phone into a gamepad, including tilt control? Just discovered that I like playing games on it, besides using its multimedia capabilities.Works very well.
Originally posted by array81 View PostI have a problem with my bluetooth gamepads (Xiaomi and ). I installed Asphalt 8 and Asphalt Xtreme. My gamepads work without problem with Asphalt 8 but not with Asphalt Xtreme.
I have the same games on my Oneplus One and I can use my gamepad without problem also with Asphalt Xtreme.
Are there same problems/bugs with bluetooth gamepads?
So I discovered that MC didn't like the wifi dongle i connected via USB that I use for keyboard.
Got rid of the dongle it worked with gamepad.
Originally posted by Andrei80 View PostHello! Just exchanged a Mini MX box for this model because the lack of RAM(1 vs 2GB) was showing.
For those complaining about slow WIFI, the fix that worked with my previous TVbox also works with this one: flip the box upside down and speed should be a solid 30Mb/s
Loving it so far. Begun to love it even more when I found out that original remote works with quite a lot of games. Beach buggy was a lot of fun for me and my children.
The only bug I have found so far is that Kodi freezes on exit, so I only minimize it...also 8GB(4.7 available) is quite low, especially when combined with the read only SDcard/USB stick whatever...
Still, it's a lot of fun! My wife called in sick for work one day because she had just discovered that she can watch almost any movie/series with this new toy and couldn't stop
Does anyone have the problem like mine? Every time I turn on my MINI M8S II box with the TV, it will automatically turn on. But when I turn it on second time, it works fine. So, when I want to use this TV box I will have to turn it on twice. Could anyone help to solve this problem? I using October ROM. Thanks a lot.
Guest
How do you turn on your mini m8s ii with the tv?
For myself,
When I turn on my Mini M8 sii with its remote, if my TV is off, by turning on the Mini M8sii it also turns the TV on and the Mini M8s ii boots directly to the launcher page.
If my TV is on and the MINI M8s ii is off and I am watching a program on my TV, when I turn on my MINI M8s ii using its remote, the TV auto changes to the mini m8 sii launcher.
If I want to switch off my TV I have to use its remote, If I want to switch off the mini m8s ii I have to use its remote.
I don't have to double boot anything.
I must say the behavior of this android box is annoying and I am waiting for some other better device to come along in 2017 so I can dump this device. Unfortunately I bought 2 of them and the last update to 106 seems to have for me really screwed this up how this box behaves.
This works as long you use Tanix TX5 Pro. I could not get TWRP to install on the stock M8S firmware. I have had no issues with Tanix on my M8S.
Originally posted by cjeman View PostNvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
I am also searching for an app that will make my phone gamepad.As for droidmote which another user proposed,i have not managed to make it work.
Regards.
Hello. I receive my box today fron gearbest. I have some problems. When i go to kodi and get out (exit) then it freeze , and also i put my google account . Playstore is ok. I download the chrome apk but it can't connect to my account. (Gmail). I tried to do update on the machine but it say that i have thr latest version. If i put the latest firmware here fix these problems? And which firmware to put on ? Thanks
There are currently 2792 users online. 1 members and 2791 guests.
