Mini M8S II 4K Smart TV Box Amlogic S905X 2/8GB WiFi 10/100 LAN BT
Originally posted by vldim View Post...
The next firmware will fix the problem with the key ENTER at USB keyboard.
Thanks for helping us be up-to-date on the firmware and developments on this box, vldim, your efforts are much appreciated.
P34c3
Originally posted by vldim View PostEverything works fine in app tTorrent. (Sorry for my bad english)
Put the program tTorrent
Go to "Settings", then select "Program Folders"
Specifies the path and write permissions.
No. I'm just a guy ...
I know the email manufacturer in China.
I write them letters. I inform them of bugs and problems. They send me the firmware.
Can you inform the manufacturer about the brightness issue? This box, since 0923, started supporting amcodec in kodi, which causes an increase in brightness to the box inside and outside of Kodi. You have to reset the box to set the brightness back to default. The only way to avoid this is by disabling amcodec in the Video -> Acceleration section of Kodi.
Youtube sometimes causes this increase in brightness, too, but not all the time.
The increase in brightness is caused by the fact that the RGB output of the box changes from a range of 0-255 where 0 is black and 255 is white (aka Full Range), to 16-235 where 16 is black and 235 is white (aka Limited Range).
UPDATED: I got black screen after updating the recent OTA. I thought it was frozen. But I switched to other HDMI input and then switched back. The box was normal again with the updated FW. I tried to reboot and got the black screen again. I had to switch the HDMI input to get rid of the black screen. I am not sure if this is the bug for the new FW.
Other question:
Is there a way to enter recovery mode and flash a rom?
What does the hidden button on the bottom do? Any combination to recovery mode? Thanks a lot.
Originally posted by xman099Hi everyone, I am not sure where I should ask my question. Please let me know if I was in the wrong place.
Recently my box was failed to update with the new OTA package. I pressed the "update now" button as usual and the screen was just frozen. I waited for about half an hour and the screen turned to black. I tried to unplugged and replugged but nothing happend. The screen was still black. I also tried to press the hidden button at the bottom for a few second. Nothing happened.
What does the hidden button do? Any combination to recovery mode? Thanks a lot.
Sent from my vivo V3Max using Tapatalk
Originally posted by ex2rock View Post
i have this problem too.... New OTA update was fail..
I just got my issue solved. The black screen after updating or reboot actually was not frozen. I switched to other HDMI input and then switched back. The box was normal with the updated FW. I tried to reboot and got the black screen again. I am not sure if this is the bug for the new FW.
Now my box updated to ver.106...thxx anyone!
Originally posted by niros View PostI'm considering a purchase of this tv box.
Would you recommend to buy it?
1. very cheap;
2. decent hardware (it would have been better with 16gb);
3. until now about 1 OTA for month;
4. rooted by manufacturer;
5. the GUI is not the best but you can replace it by play store.
There are currently 2043 users online. 0 members and 2043 guests.
